cooling problems
08-10-2008, 11:30 PM
cooling problems
recently I put a electric fan and only temp. switch that I can find to fit was one that turn on the fan on 85C
and now fan is working almost constantly . can anybody recommend wright temperature switch? and what is normal working temp. for 4age bluetop? thanks "Faster, Faster, until the thrill of speed overcomes the fear of death." -Hunter S. Thompson |
08-11-2008, 01:00 AM
cooling problems
85 is good for racing use
84' AE86 Levin 96' 500HP WRX, powered by landikar
08-12-2008, 05:50 AM
cooling problems
I just wired mine directly to the ignition. No need for a temp switch.
08-12-2008, 12:33 PM
cooling problems
F0Bman Wrote:I just wired mine directly to the ignition. No need for a temp switch.can you explain this ? post some pictures please. thanks "Faster, Faster, until the thrill of speed overcomes the fear of death." -Hunter S. Thompson |
08-19-2008, 07:59 AM
cooling problems
Connect the positive end to the IGNITION fuse in the fuse box. This will power up when the key is in, and power down when fully shut off.
08-19-2008, 12:16 PM
cooling problems
Typically, the radiator thermostat will start to open at 82-85 deg and
be fully open at >90 deg. This indicates that the thermostat is trying to maintain an engine temperature between 85 and 90 degrees. It does this by adjusting the amount of water flowing thru the radiator. Electrically operated fans are normally off when the car is traveling at any reasonable speed. The flow of air thru the radiator is sufficient for engine cooling. The fan should really only turn on when the car is stuck in traffic, and there is no airflow thru the radiator due to movement of the vehicle. Try locating the temperature switch in a cooler part of the water circuit. The bottom of the radiator is much cooler than the top. All the factory temperature switches I have seen are either near the bottom of the radiator, or in the return pipe. Don't put your switch in the hose taking water to the radiator !!! If you do it will run all the time and be really annoying Cheers... jondee86 |
08-19-2008, 08:55 PM
cooling problems
thanks jondee86 !!
that is the info that I need. I located the temp switch in the lower hose but next to the thermostat , will correct that soon. thank again "Faster, Faster, until the thrill of speed overcomes the fear of death." -Hunter S. Thompson |
| Improve 20V Blacktop cooling | pack | 0 | 2,362 |
06-07-2023 01:18 PM Last Post: pack |
| Big wheel problems | gh0st | 16 | 15,014 |
| Starting problems 4-AGE kouki | Hanzo | 3 | 4,869 |
| Problems Mintex M1155 pads | Dino86 | 9 | 12,945 |
07-04-2017 11:22 AM Last Post: totta Crolla |
| 16v Bigport fuel problems | Rascal21 | 1 | 6,437 |
07-04-2015 01:00 AM Last Post: jondee86 |
