converting afm to map
08-16-2007, 02:10 PM
I would like to convert my blue top 4age from AFM to MAP.
What do I need?
MAP sensor
ECU?
08-16-2007, 02:59 PM
As far as I know, if you have a Swiss afm hachi with 4agec (note the C), you won't gain much power with this type of conversion.
To obtain the same power that map sensored hachies have, you should use also the pistons from map sensored hachi.
The pistons used in Swiss hachies are different (lower compression) that the ones used in map spec. 4age.
Regards
Andrej
Big Grin map sensor cheating? fdsjakl890 8 4,429 08-26-2025 01:12 PM
  Converting Jap Spec wing mirrors to UK spec chrisae86 5 5,591 04-12-2022 11:03 PM
Last Post: chrisae86
  AFM to Map Conversion ps13michi 3 6,753 01-06-2022 10:34 AM
Last Post: ps13michi
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 19,498 02-10-2020 06:39 PM
Last Post: Power_uP
  extracted freedom ecu 16v ignition map ditn 7 13,327 08-22-2016 10:01 AM
Last Post: ditn
