co idle mixture - discussion
07-12-2012, 08:01 AM
Andrax Wrote:Its normal that the CO values are not stable. The ECU is always trying to adjust it, so you wont get a linear value. As said, set it on the factory specs. Anyway, after a few kilometers it will get out of specs again... Goodmorning! ok i understood it is not stable,i adjusted them on the factory specs the last time.... but if the ecu will "change"" them which is the meaning of adjusting them?.. 4age 16v to FR 20VT |
07-13-2012, 02:31 PM
it is very important to inform me ,if the ecu self - adjust the co mixture!
if it does then when i adjust it to the oem specs, then the ecu will change them? 4age 16v to FR 20VT |
| Blacktop 20V high idle | Bravothreezero | 3 | 561 |
08-28-2026 01:11 PM Last Post: jdm86gtz |
| No idle below 2000 rpm rich running | Steller Engineering | 3 | 4,066 |
| Engine starts/revs but no idle | GenkiMotors | 17 | 14,348 |
| exhaust odor/idle MOT issue | Ryo | 7 | 11,164 |
| 20v silvertop idle issue | AlexFourTwenty | 3 | 7,470 |
