clutch pump on the geaboxx
03-14-2013, 09:50 PM
my clutch pump was leaking so I installed another but this is not the same
it fits but it is not aligned properly and the clutch will not release completely
and it slipps
is there is a difference in clutch pumps?
u cann see a deferince but it fitss
03-15-2013, 01:35 AM
http://imageshack.us/photo/my-images/136...330175.png
Any of these?
Dan -
03-15-2013, 09:00 AM
oldeskewltoy Wrote:http://imageshack.us/photo/my-images/136...330175.png
Any of these?
The old one is the same
The new not the rod is different
03-15-2013, 04:39 PM
Are the rod lengths the same on the old one and the new one ?
03-15-2013, 04:51 PM
You can see the difference but it fits, there is the problem. You need the exact replacement, all slave cylinders that I have seen are the same, but what country are you in because there are variences in t50 bell housings, left/right
03-15-2013, 05:25 PM
The slave's rod length only matters in the extremes - too long and the clutch will not engage completely because the piston will bottom out in the slave cyl., too short and the clutch will not dis-engage because the piston pops out of the
cylinder.
I really don't have a clue about your problem.
Can you explain it any better then 'will not release completely
and it slipps'????? To me that means that it neither engages completely nor dis-engages completely, pedal only does half a job whether on the floor or all the way up.
03-20-2013, 01:40 PM
allencr Wrote:The slave's rod length only matters in the extremes - too long and the clutch will not engage completely because the piston will bottom out in the slave cyl., too short and the clutch will not dis-engage because the piston pops out of the
cylinder.
disengages not completly pedal is all the way up
i will look 4 pics the strange thing is it came of a ae86 my spareparts car
03-20-2013, 03:48 PM
Sorry, I still don't get it.
Disengaged = clutch does not connect engine with the drivetrain, transmission to the wheels, the clutch pedal is on the floor
Engaged - pedal is all the way up, engine is connected to the transmission.
03-20-2013, 03:51 PM
I believe what he mean is when the pedal is all the way up the clutch stay disengaged (or not fully engaged)
03-20-2013, 09:01 PM
Clutch not engaging = bad clutch or a very long slave cyl. pushrod that has bottomed out & would be very difficult to install & feel rock solid if you try to move it or the clutch fork.
  20v BT - which oil pump? Mylesmck 4 5,696 06-21-2022 04:51 PM
Last Post: pack
  Fuel pump issue DJexor 11 10,920 04-29-2022 05:45 AM
  fuel line hose from the pump Wikizz 4 8,325 10-16-2017 07:11 PM
Last Post: jdm86gtz
  4age smallport oil pump in bigport engine? ditn 2 10,201 12-06-2014 08:10 PM
Last Post: ditn
  Oil pump question megabob 2 6,381 03-05-2014 05:37 AM
