clutch master cyl
03-31-2009, 10:14 PM
clutch master cyl
hey i replaced my clutch master cylinder and now i have a problem. The joint where the hard line attaches to the master cylinder is leaking fluid.
Is there anything i can seal with as i know clutch fluid is a pain to seal something like silicone ? i will try tighten it harder as the nut hasn't reached the the body of the cylinder
thx
Alex
04-01-2009, 09:02 PM
clutch master cyl
Usually the leak is caused by the pipe not seating properly, tightening it up more may ruin the flange on the pipe.
Try undoing the union until it is almost out then pull the pipe hard, this should seat the pipe square against the union, continue pulling whilst doing up the union. hth TC
04-01-2009, 09:40 PM
clutch master cyl
cool will give it a try
04-02-2009, 01:36 PM
clutch master cyl
hey guys im having trouble with my clutch master cylinder and i need to use a die and tap to clean some threads as i messed them up. Could anyboy tell me the sizes i need and wht are the numbers mean on the cylinder body above where the hard lines go ?
thx
Alex
04-02-2009, 03:24 PM
clutch master cyl
the number(s) on the cylinder is most likely the bore size (13/16") but IIRC the lines use a 10mm. it's really easy to cross-thread the hard line fittings in the master cylinder. you'd be better off replacing the MC than trying to re-thread it in my opinion.
if you choose to replace the MC, try lining up the cylinder where it aught to go w/o bolting it down, then carefully begin to thread in the hard lines. by not securing the MC first, it gives you room to play in order to line things up. good luck.
[Image: AEU86 AE86 - clutch master cyl]
"Strictly All Things 86"
04-02-2009, 10:51 PM
clutch master cyl
thx guys ive sorted this probs and no leaking from the cylinder now Thumbs up! thxs very much
  Bigger brake master cylinder options Koen 10 3,401 01-08-2026 03:12 PM
Last Post: r.ave
  Brake advice - master cylinder mannix20vt 12 20,086 08-21-2017 03:21 PM
Last Post: Project D
  Correct connection brake master cylinder? bozu 5 10,100 07-26-2015 12:28 PM
Last Post: bozu
  Dimensions clutch master cylinder bozu 2 8,358 04-16-2015 07:11 AM
Last Post: bozu
  Where to buy new master and slave clutch cylinders? krullibull 6 10,259 06-27-2013 07:57 PM
Last Post: krullibull
