changing from electric moter windows to winders big job?
03-25-2011, 09:27 PM
changing from electric moter windows to winders big job? wats needed? any1 help?
85 trueno project Tongue
01 corolla dailydriver Smile
http://www.facebook.com/profile.php?id=100000579907701
03-26-2011, 12:18 AM
You will need:
window regulator for manual windows
door panels for manual windows
window crank for manual windows
The replacement is time consuming, but not especially hard. There is a special tool that makes this easier... 2 suction cups on a strap... that way you can "hold up" the window while removing the regulator
Dan -
03-26-2011, 07:12 PM
ok panels and cranks arent a problem is the regulater hard sourced?
03-27-2011, 04:30 AM
new? not easily available....
used? I'm on the west coast of the USA... I have little knowledge of Irelands used parts... BUT since manual is far more prevalent then power... I say it is likely easy to find said parts
It might be cheaper to buy a pair of doors....... Huh
Dan -
03-31-2011, 08:39 PM
would you want to swap your electric parts for my manual parts?
  Electric windows totta Crolla 0 1,126 03-18-2025 11:00 PM
Last Post: totta Crolla
  Big wheel problems gh0st 16 11,740 11-15-2021 10:51 PM
Last Post: gh0st
  20v mains & big end bearing izanagi 9 12,357 12-26-2016 12:42 PM
Last Post: pack
  Front big brake kit DidiDex 14 21,526 10-24-2016 09:29 AM
Last Post: FanIsHere
  Changing distributor when carb 4age izanagi 14 18,876 07-04-2016 03:27 PM
Last Post: Uzelac
