cams cams cams
09-13-2013, 12:51 PM
Post: #41
cams cams cams
I'm currently looking at a pair of Adjustable Cam Gear:
http://www.ebay.co.uk/itm/221008147565?s...1438.l2649 http://www.ebay.co.uk/itm/271271298398?s...1438.l2649 to be honest is there really going to be any difference between the 2 in build quality, obviously i done want the cam gears breaking free and causing some bent valves and dented pistons ![]() |
09-13-2013, 01:00 PM
Post: #42
cams cams cams
What ever you get make sure the edges are smooth to avoid excessive wear on the belt.
AE86 ex-daily |
09-13-2013, 02:56 PM
Post: #43
cams cams cams
megabob Wrote:I'm currently looking at a pair of Adjustable Cam Gear: I got those and they are fine ![]() |
09-13-2013, 05:30 PM
Post: #44
cams cams cams
Ideal next month will be new cams and gears
09-13-2013, 07:30 PM
Post: #45
cams cams cams
there can be differences in cam gears.... mostly based on the pin diameters....
check for pin fit... either no fit... T3 type with an "opened" up pin hole ![]() or loose fit - SS Works timing pulleys ![]() I eventually went with the T3, I opened them up for a perfect zero tolerance (no slop) fit Oh... there is another problem with the T3 pulleys... I was able to overcome once they told me... they mis-machined the location of the opening for the intake pin... they did tell me how to fix it... I made a diagram to better understand how to set T3 timing ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
09-20-2013, 07:44 PM
Post: #46
cams cams cams
Alex170984 Wrote:Hi All, Hmmm, are those the Catcams??? The exhaust cam lobes appear to have an unusual shape to them...... Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
09-20-2013, 11:44 PM
Post: #47
cams cams cams
![]() An analogue brain in a digital World |
09-23-2013, 03:11 PM
Post: #48
cams cams cams
It's at home on my window sill in a jiffy bag but I haven't been at home recently and the mr2 has been a royal PITA.
The cams are dialled it and are working fine. Yes they are CatCams. |
09-24-2013, 10:44 PM
Post: #49
cams cams cams
Alex I deleted that post after a couple of hours and I have been away for a few days since and it has mysteriously reappeared !
I will delete it again. An analogue brain in a digital World |
10-24-2013, 12:39 PM
Post: #50
cams cams cams
Hi guys,
Just thought i would let you all know I have now put in the cams with the adjustable gears: ![]() Was super easy as i only had the change 1 shim! still need to adjust the timing as its lacking power at the bottom and mid range which is a job for tomorrow. will also need to check the jetting to make sure its not running lean[/img] ![]() |
