cams cams cams
08-29-2013, 01:31 PM
cams cams cams
Hi Guys,
Yes its another cam discussion I have a stock 4AGE with a slightly skimmed head running Mikuni PHH44 carbs and Janspeed 4-1 manifold with full Janspeed exhaust system. Shes being used as a weekend car so not a daily drive, so i could stand to loose a little low end torque/power. I've been looking at the following: - Kent cams, 282 Deg Inlet/Exhaust http://www.kentcams.com/product-details/...mpetition/ - Piper cams, 288 Deg Inlet/Exhaust http://www.pipercams.co.uk/pipercams/www...OY16VBP285 - Cat cams, 282 Deg Inlet/275 Exhaust http://www.catcams.co.uk/acatalog/7105140.pdf My 86 was dyno'ed at 127HP and my goal is about 140HP, nothing too crazy, don't wanna spoil the balance. If anyone knows which would be best or any alternatives then all info is appreciated
08-29-2013, 01:40 PM
cams cams cams
What cam setup are you running at the time, stock cams?
140HP can made with cams in the 264° range, 282° or 288° sounds more like 150HP+
08-29-2013, 01:54 PM
cams cams cams
this catcams setup can do the job : http://www.catcams.com/products/camshaft...TUP_id=828
look at this post you will see makkuro he reached your goal : http://www.aeu86.org/viewtopic/my-86-dyn...13/t/13629 |
08-29-2013, 02:20 PM
cams cams cams
d3nso - Yeah stock cams at the mo
superli - Thanks for the link looks like my goal is a little easier than i thought Looks like I'm going higher than i need to I'll look into something a little milder. Cheers guys
08-30-2013, 12:26 AM
cams cams cams
superli Wrote:look at this post you will see makkuro he reached your goal.As oldeskewltoy will tell you... increased cam duration will require raised compression to get the best out of the cams (rule of thumb ). Note that makkuro cut the head and used a thin metal head gasket when re-building his engine. He got 134 rwhp (and wheel hp is the only accurate measure of hp). So if you already have 127 rwhp, a set of cams should be all you need. But if that 127 hp is engine hp back-calculated from wheel hp, then it will take more than a set of cams. Pedantic... yes There is a lot of confusion caused by people "guessing" engine power, based on wheel hp dynometer measurements, and it pays to be crystal clear when seeking advice. WHEEL HP IS THE ONLY VALID FIGURE... ALL ELSE IS BS!!! Unless you are using an engine dyno of course Cheers... jondee86 |
08-30-2013, 07:24 AM
cams cams cams
Wheel-hp will vary as much as 20% between dyno's and is as useless as engine hp. Sometimes more (see e.g. Mahle dyno's or dynojet dynopac)
08-30-2013, 08:47 AM
cams cams cams
NoHachi Wrote:Wheel-hp will vary as much as 20% between dyno's and is as useless as engine hp. Sometimes more (see e.g. Mahle dyno's or dynojet dynopac) agree Wheel-hp will vary with the grip on your tyres, the pressure on your tyres, the oil on your gearbox,etc etc ... you are better off with the calculated HP because on the coast down the dyno calculates the losses of your tyres/transmission/etc. Unless we are talking about hub dynos (the ones you remove the alloys and bolt the hub on the dyno) PS: I have some cams to sell (TODA 288 8.5 IN and HKS 272 8.1 EX) they gave me 161bhp with throttle bodies and a skimmed head and made a very nice round engine. Drop me a PM if interested |
08-30-2013, 10:05 AM
cams cams cams
NoHachi Wrote:Wheel-hp will vary as much as 20% between dyno's and is as useless asYes, understood. But providing you use the same dyno each time, you should be able to measure any change (+/-) due to modifications you have been making. I can't think of any other reason for using a dyno And personally, I would never use an inertia dyno when there was a hub dyno available. [plug]And being designed and built in NZ means Dynapak hub dynos are used by all our top tuners.[/plug] Cheers... jondee86 |
08-30-2013, 10:41 AM
cams cams cams
gon Wrote:... on the coast down the dyno calculates the losses of yourThe problem with using the coast down figure for transmission loss, is that it does not take account of the power lost to friction when the power train is fully loaded at WOT. The hypoid bevel differential is said to absorb from 5 to 10% of transmitted power, and obviously the power loss will be much greater at WOT than it is at coast down with the clutch disengaged. Idealy, power should be measured at constant rpm, to eliminate the power lost in overcoming the inertia of the rotating parts of the drivetrain (wheels and tyres, driveshaft etc). However, providing you use the same dyno for each run, and try and keep all the other variables (temperature, wheels, tyres etc) the same, the difference between wheel hp from run to run will be a useful readout. Who are you really fooling if you shop around to find the highest reading dyno, just so you can "make" an extra 5 or 10 hp ??? Cheers... jondee86 |
08-30-2013, 02:21 PM
cams cams cams
Hi
As mentioned you dont need nearly as aggressive cams to make ~140 crank-hp (must be since your std setup delivers 127). My previous engine made 150hp with 256 Cat-cams and my current make 189 with 290 Kent-cams. Measured on the same dyno
