brake master cylinder ( 4 holes )
12-27-2012, 10:14 AM
Hi,
I was looking for a new brake master cylinder 4 holes. found one on rockauto http://www.rockauto.com/catalog/moreinfo...&cc=171545 but if image is correct the hose fittings are on the wrong side. and if you compare the oem part numbers on that part they are for the early model with 2 holes. toyodiy: part no 47201‑12510 late model 47201-12370 early model I searched on ebay but couldnt find any. dont really want to buy expensive oem toyota stuff anyone a suggestion ? cheers, Tom http://nuudelbahn.wordpress.com/ http://www.superlapbattle.lu https://www.facebook.com/SLBRaceleague |
12-27-2012, 11:54 AM
hi tom
look into Supra MK3 http://www.ebay.de/itm/Hauptbremszylinde...484b9ffe24 there is a few on ebay |
12-27-2012, 12:26 PM
wrong side outlets on supra too. should be poited right or 45° angle right
Eifelaner Wrote:hi tom http://nuudelbahn.wordpress.com/ http://www.superlapbattle.lu https://www.facebook.com/SLBRaceleague |
12-27-2012, 12:28 PM
Why you search 4 holes brake master cylinder ?
On your links the picture is not correct, like you say in toyodiy with reference brake master cylinder had 2 holes. If you have your old reference of your 4 holes brake master cylinder you can find it ! |
12-27-2012, 01:19 PM
cedr94 Wrote:Why you search 4 holes brake master cylinder ? I need a 4 holes bmc. oem part reference on rockauto is wrong. yes i can find it at toyota for +300euros http://nuudelbahn.wordpress.com/ http://www.superlapbattle.lu https://www.facebook.com/SLBRaceleague |
12-27-2012, 03:05 PM
Why you need 4 hole? can get a bias pedal box cheaper then 300yoyo
12-27-2012, 04:12 PM
I do have the same 4 hole BMC - I got away with a rebuild kit though. was less than 10$
AE86 ex-daily |
| Bigger brake master cylinder options | Koen | 10 | 2,238 |
01-08-2026 03:12 PM Last Post: r.ave |
| 4AGE cylinder head plug removal | Ivan141 | 5 | 4,815 |
| Brake advice - master cylinder | mannix20vt | 12 | 18,814 |
| Correct connection brake master cylinder? | bozu | 5 | 9,455 |
| torque setting head cylinder bolts | izanagi | 1 | 6,486 |
05-29-2015 01:23 AM Last Post: oldeskewltoy |
