brake master cylinder ( 4 holes )
12-27-2012, 10:14 AM
Hi,
I was looking for a new brake master cylinder 4 holes. found one on rockauto
http://www.rockauto.com/catalog/moreinfo...&cc=171545
but if image is correct the hose fittings are on the wrong side.
and if you compare the oem part numbers on that part they are for the early model with 2 holes.
toyodiy: part no 47201‑12510 late model
47201-12370 early model
I searched on ebay but couldnt find any.
dont really want to buy expensive oem toyota stuff
anyone a suggestion ?
cheers,
Tom
http://nuudelbahn.wordpress.com/
http://www.superlapbattle.lu
https://www.facebook.com/SLBRaceleague
12-27-2012, 11:54 AM
hi tom Wave
look into Supra MK3
http://www.ebay.de/itm/Hauptbremszylinde...484b9ffe24
there is a few on ebay
12-27-2012, 12:26 PM
wrong side outlets on supra too. should be poited right or 45° angle right
Eifelaner Wrote:hi tom Wave
look into Supra MK3
12-27-2012, 12:28 PM
Why you search 4 holes brake master cylinder ?
On your links the picture is not correct, like you say in toyodiy with reference
brake master cylinder had 2 holes.
If you have your old reference of your 4 holes brake master cylinder you can find it !
12-27-2012, 01:19 PM
cedr94 Wrote:Why you search 4 holes brake master cylinder ?
I need a 4 holes bmc. oem part reference on rockauto is wrong.
yes i can find it at toyota for +300euros
12-27-2012, 03:05 PM
Why you need 4 hole? can get a bias pedal box cheaper then 300yoyo
12-27-2012, 04:12 PM
I do have the same 4 hole BMC - I got away with a rebuild kit though. was less than 10$ Smile
  Bigger brake master cylinder options Koen Bongers 3 353 11-25-2025 09:05 AM
  4AGE cylinder head plug removal Ivan141 5 3,798 09-30-2023 09:47 PM
  Brake advice - master cylinder mannix20vt 12 17,457 08-21-2017 03:21 PM
Last Post: Project D
  Correct connection brake master cylinder? bozu 5 8,754 07-26-2015 12:28 PM
Last Post: bozu
  torque setting head cylinder bolts izanagi 1 5,871 05-29-2015 01:23 AM
