and im off AE86 trueno, Silvertop project, but wait SR5?
10-25-2006, 06:41 AM
Post: #31
Just and update, with pics this time...
and for Nohachi, I've dones this in my "four day weekend" |
10-25-2006, 09:19 AM
Post: #32
Ah looks like you're on your way to get her running
![]() Any ideas yet when you'll be starting on the swap or have you desided to let that rest for awhile? Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
10-25-2006, 03:57 PM
Post: #33
Well, after I looked at the vems loom I am thinkning that I am going to go with that, its about 300 dollars, and I can get a silvertop loom for 200, but with the vems loom I dont have to cut into the firewall for the distrubiter, which just makes life that much easier. So first I will have to come up with some money, then I will be able to continue with the swap.
10-25-2006, 04:48 PM
Post: #34
Its just 300 for the loom right? Not including the VEMS unit itself...Count on around 1000$ to 1200$ for a complete VEMS setup. Support for the VEMS seems to better in Europe then the US. Consider a MegaSquirt..its less powerfull, but better supported at your end of the pond and a bit cheaper.
11-07-2006, 07:11 AM
Post: #35
Yeah, your right noHachi *meh* oh well that'll be a later project,
But She runs, and back on the road! |
01-03-2007, 07:36 AM
Post: #36
Well it definatly has been a long time since I have posted anything.
but a few things have changed. I have set up a stereo in my car now, Sony Xplod. As well as I finally got enough money to get a megasquirt system. As soon as I buy it and put it together, test it, all that good stuff Im pulling my 86 in to do an engine swap. ![]() |
01-25-2007, 09:18 AM
Post: #37
Alright, I am looking for a fuel pump, would this one work?
http://www.treperformance.com/FuelPumps/...Pumps.html its like $70 so its not too bad. |
01-26-2007, 08:26 AM
Post: #38
Is anyone going to answer??? or have you all figured this thread dead?
01-26-2007, 10:06 AM
Post: #39
Nah, I think people are just busy atm, its middle of the week you know
![]() I have no idea if this is a good fuel pump. Doesn't really list the GT so you may need to do some alterations, then again, having an SR5 fuel tank you prolly need to do that anyways ![]() Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
01-26-2007, 10:34 AM
Post: #40
255hp fuelpump might overpower the stock regulator..that would give you to high fuel pressure..I'm not 100% sure, so its worth researching..
Scuderia rollator CE86 trueno project | NoHachi | 136 | 171,844 |
04-15-2013 05:53 PM Last Post: [Walaki]D`Lair |
my slow trueno project | cfly86 | 38 | 47,999 |
12-12-2012 04:35 AM Last Post: cfly86 |
My Drift project - 83' Trueno coupe | doggy | 158 | 293,251 |
10-23-2012 10:58 AM Last Post: Lightning |
1986 Corolla SR5 S2k Build.... MIami style | geoscranny84 | 16 | 24,767 |
04-26-2012 08:00 PM Last Post: [Walaki]D`Lair |
1987 sr5 project | purplerain11 | 3 | 6,948 |
04-15-2012 03:34 AM Last Post: purplerain11 |
