alternator
03-31-2009, 07:33 PM
alternator
Is there a way to get rid of the "pump"(with yellow arrow) so that i can use a belt like the red line??
Yaris 1.3 xp9
Yaris 1.0 p1
Mercedes citan
weekend driver 1985 AE86
03-31-2009, 10:47 PM
alternator
Remove the power steering, i guess...loop the lines or install a regular steering rack, then find yourself a belt of the correct dimensions.
By the way, what's your alternator doing down there? Making room for the supercharger?
04-01-2009, 08:40 PM
alternator
yup its a supercharger engine :wink:
I'm just searching for a shorter belt
Yaris 1.3 xp9
Yaris 1.0 p1
Mercedes citan
04-02-2009, 04:12 PM
alternator
is the alternator adjustable in the sense that it sits on a pivot bolt at the bottom and then has a second bolt up top that slides on a slotted bracket?
[Image: AEU86 AE86 - alternator]
"Strictly All Things 86"
04-02-2009, 07:30 PM
alternator
No the alternator is not adjustable on the bracket but i was thinking to make new bracket like on the 4age but then for the other side of the engine
Yaris 1.3 xp9
Yaris 1.0 p1
Mercedes citan
04-02-2009, 10:08 PM
alternator
looking at the size of the ps pump/alt bracket, would it be feasible to tap into it for 1/2 bolts to mount an upper slide bracket say from a 4AC or 3TC motor?
here:
4ac alt bracket
3TC alt bracket (aftermarket by BRD here) top bracket. pay no attention to the bottom one.
04-03-2009, 09:27 PM
alternator
yes something like the bottom pic is wath i mean :wink:
Yaris 1.3 xp9
Yaris 1.0 p1
Mercedes citan
05-22-2009, 09:23 PM
alternator
Is there anyone who knows if there's a shorter belt (+/- 5cm) then a stock 4age belt??
Yaris 1.3 xp9
Yaris 1.0 p1
Mercedes citan
06-08-2009, 09:12 PM
alternator
You should be able to get a whole variety of belts. When we rebuild something. (move stuff and such) we usually just measure up the length the belt needs to be with a cut oversized belt. And go order a new one thats exactly the same length and have correct tracks.
Kp62 - 135hp
Ae86 - 135hp
C32 Laurel - 440hp
C32 Laurel - 125hp
06-09-2009, 07:05 PM
alternator
@gnugfur aftermarket or stock belts?
Yaris 1.3 xp9
Yaris 1.0 p1
Mercedes citan
  20v swap alternator izanagi 3 7,480 12-15-2016 01:11 PM
Last Post: pack
  85 amp alternator? heshan 4 10,378 06-12-2012 08:03 PM
Last Post: heshan
  Help! Lost tachometer, water t. gauge, alternator wont charg Saber 9 17,128 05-21-2012 08:06 PM
Last Post: Saber
  AE86 Alternator Snejk 5 9,442 09-25-2009 03:18 PM
Last Post: Snejk
  Alternator rebuild max_ae86 6 9,430 04-22-2008 09:42 AM
Last Post: max_ae86
