ae92 shocks
01-11-2007, 03:50 PM
ae92 shocks
calculate how much to cut - and that's all
You can always shim a little putting big washers under the spacer. |
01-11-2007, 04:48 PM
ae92 shocks
when you say calculate Jammie how can i do this ? measure what ?
can you be more specific? AE86 FANATIC!!! |
01-11-2007, 04:51 PM
ae92 shocks
Yes.
Compare your stock shock inserts with the new one. If new ones are shorter 60mm and you have 30mm spacers (for example) - calculation is 60-30=30 (to cut). |
01-12-2007, 01:02 AM
ae92 shocks
what is the length of the stock shock?
Maybe we could list all those lengths of different common used shocks(Blues, HTS, konis86/92 etc) in the technical FAQ. As those are often asked (eg. are those shortstrokes, how much to cut, spacers ,etc). Better overview for less pro's (me=noob Just an idea...
An '86 86 driver Zenki AE86 Levin coupe |
01-12-2007, 04:08 AM
ae92 shocks
i ment these ones sorry for the mix up
01-12-2007, 09:42 AM
ae92 shocks
where do you put these Mr Monster ?
AE86 FANATIC!!! |
01-12-2007, 10:22 AM
ae92 shocks
On top of the strut tube, instead of the nut that usually sits there.
01-12-2007, 10:56 AM
ae92 shocks
kungfumaster Wrote:what is the length of the stock shock?Here's a short table of shock lengths I did while looking for something suitable for my car - these are collected from various sources on the net. [code:1] front shock cartridges; Model Body Shaft Ext Comp -------------------------------------------------------------------------- AE86 standard 44 22 610 410 TRD race oil 48511-TE701 44 22 535 416 TRD race gas 48511-AE031 44 22 477 351 SW20 rear 43 22 516 373 TRD AE92 48511-AE982 42.7 22 485 341 rear shocks; Model Ext Comp --------------------------------------------------------------------- AE86, AE71, TE72, AE95, TA22, RA23, AL25 564 339 AE86 TRD race oil 502 337 AE86 TRD race gas 473 293 XT130, ST141, KE36, RA40, RA60, AE70 van 482 297 KE30, RT40, Commodore wagon 517 307 1982-02 Camaro 524 325 1978-81 Supra 485 318 1969-77 Skyline Tokico Prodra-G 485 ? [/code:1] |
01-12-2007, 11:00 AM
ae92 shocks
less expensive is to use 3cm (or what your need size) spacer from polyurethane or aluminium over the shock, you dont need to cut your struts with those or with this T3 stuff.
01-12-2007, 11:38 AM
ae92 shocks
this is from garage dori
http://www.garagedori.com/tech/suspensio..._guide.php Measurement Guide: Front Shocks (inserts): Extended Length = Extended length is from the bottom of the shock, to the bottom of the thread. (Not necessarily where the top spring carrier sits.) Body Length = Bottom of the body, to the top... pretty straight forward. Stroke Length = Extended length - Body... again, straight forward. Rear Shocks (eye bottom, pin top): Extended length = Center of the eye, to the bottom of the pin. Body Length = Bottom of the body, to the top... Closed Length = Center of the eye, to the bottom of the pin when compressed Front Insert Dimensions: AE86 Body length: 402mm Extended length: 604mm Extended minus Body: 202mm Outside Diameter: 43.5mm AE92: Body length: 336mm Extended length: 500mm Extended minus Body: 164mm Outside Diameter: 43.5mm Celica T/RA63 Body length: 405mm Extended length: 605mm (3dr hatch maybe shorter then this) Extended minus Body: 200mm Outside Diameter: 43.5mm Shaft diameter: 22mm Corolla KE35: Body length: 414mm Extended length: 613mm Extended minus Body: 199mm Outside Diameter: 38mm Corona TT132 Body length: 403mm Extended length: 600mm Extended minus Body: 197mm Outside Diameter: 43.5mm AW11 S/C (rear shock) Body length: 345mm Outside Diameter: 43.5mm Tokico HTS Body length: 332mm Extended length: 476mm Extended minus Body: 144mm Outside Diameter: 43.5mm Rear Shocks Dimensions: AE86 Extended Length: 560mm Closed Length: 335mm Peugeot 505 Extended length: 420mm Extended minus Body: 270mm KYB Twin Tube (Oil) Rating (344004): 1900/600 Toyota Cressida/Mark II GX70 Station Wagon Dimensions unknown but good for AE86 rear shock, sim to Peugeot above, maybe stiffer Hilux (front shock) Extended length: 420mm KYB Monotube (Gas) Rating (KG5437): 3100/1000 Mazda RX-7 Gen 1 Extended Length: 540mm Closed Length: 323mm Celica T/RA63 Extended Length: 620mm Closed Length: 320mm '82 Camaro (16" wheels) Extended Length: 486mm Closed Length: 309mm Tokico HTS Extended Length: 455mm Closed Length: 307.5mm |
| rear bilstein B6 shocks 2 types what to choose? | Ryo | 5 | 5,930 |
| KONI Sports shocks for the AE86... | jondee86 | 11 | 25,603 |
| Question about KONI shocks for an AE92 | Apsogos | 1 | 5,184 |
09-13-2013 07:40 AM Last Post: Apsogos |
| ae92 external thermostat housing plumbing? | danny 86 | 2 | 6,294 |
08-15-2013 12:38 AM Last Post: fax0815 |
| Annoying sound (Ae92 hatch gti) | Apsogos | 2 | 5,874 |
01-02-2013 12:13 PM Last Post: Apsogos |
