ae86 Trueno f20c Built to be driven not polished
08-14-2013, 06:18 AM
Martynas Wrote:
ae86drftr Wrote:Can you post pics of the mods to the rear end to fit previa axles....Thanks :-)
Shortly, some Previas have solid rear axle, so all was to do, was to remove brackets from Previa axle, then nicely remove brackets from ae86 axle and weld them onto Previa axle, which appears to be extremely similar to ae86 axle only 11cm wider.
LSD is from lexus is200 that fits perfectly bolt on Previa's diff.
Halfshaft studs were made to 4x114 to fill ae86 wheels.
Other mods were coilovers and brakes, that will show on pics that will add later as that will save thousand words Smile
Perfect thanks bro....awaiting pics Smile
10-31-2013, 11:37 PM
So, axle swap. I wish I made pics before it was fitted, however literally axle looks identical to original ae86 axle only 11cm wider.
[Image: AEU86 AE86 - ae86 Trueno f20c Built to b...t polished]
Coilover fitted:
10-31-2013, 11:38 PM
And brakes
10-31-2013, 11:42 PM
Something more visible is carbon fiber bonnet, that weights 7kg which is good improvement over original one
06-14-2015, 02:30 PM
More update. As Tein coilovers started leaking and brake calipers stopped working properly due to their age, had to do some upgrades. Considering ridiculous cost of ae86 aftermarket stuff went for a bit more affordable option, s13 front suspension setup.
After spending long and cold winter nights in the garage managed to get quite a nice result. Have to say that was quite easy and straight forward mod. S13 lower control arms, AW11 steering ends, s13 rod ends, s13 hubs, s14 brake calipers, 290mm s13 brake rotors, s13 coilovers, and most of that is pretty much bolt on swap.
The benefit is super efficient brakes, extra lock and 5cm wider stance. Really like it Smile
06-14-2015, 03:42 PM
Oh and to match the calipers replaced master brake cylinder and booster to s2000 brake cylinder and booster. That was again bolt-on swap and a massive brake improvement
06-16-2015, 12:56 PM
Why have I only just seen this :S
Sweet build buddy Smile did you chop and move the tunnel up for this or space the subframe out?
I know the subframe space makes a fair difference to front GEO but might hold some benefit in lowering COG.
How's the F20 lump been treating you? Smile
Running the S2000 ecu with the AE86 interior loom so all works as it should?
06-17-2015, 02:54 PM
Thanks! Smile
f20c in my opinion was the best thing that happened to this ae86. Of course, I believe most ae86'ers are purists and accept only 4age. I was thinking the same, however, once you get to tuning 4age that gets a difficult job, that involves significant skill and investment as well. Tuned engine's reliability to be fair may not be great as well. So, that leads to a standart f20c which offers all performance ae86 would ever need with the benefit of superb reliability. The weight is pretty much the same as 4age as f20c has aluminium block. So answer is f20c is treating me extremely well Smile
Interior loom was working fine, however eventually replaced as because of the age ae86 loom was causing constant problems due to oxidation of connections, wires etc until eventually some wires simply started melting due to short circuit.
08-05-2015, 12:57 PM (This post was last modified: 08-05-2015 01:12 PM by Martynas.)
An update.
Apparantly front arches appeared to be a bit tight for wider s13 suspension and wheels size 15x8 et0, so despite how much i like the natural looking arches, had no choice but to fit CBY fenders:
Always thought the can not be too agressive, however I'm afraid now it may look a bit too agressive for a ae86.
05-05-2016, 08:29 PM
Weekend at Japfest 2016 at Silverstone.
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 3,590 10-28-2022 08:23 AM
Last Post: decryphe
  NOT SO Duty Free Trueno Hama86 25 30,174 08-16-2021 09:54 PM
  Racecar: TRD USA built ITA AE86 oldeskewltoy 38 51,749 07-22-2019 02:55 PM
Last Post: apardal
  BT20V out F20C in !! malejyetti 54 79,907 06-17-2015 07:05 PM
  wiring digram for an f20c to ae86 ae86 for sale 0 5,507 05-21-2014 11:52 PM
Last Post: ae86 for sale
