about 5mm TRD headgasket
12-11-2006, 01:24 PM
Hoey Wrote:what is the stock thickness on the small and bigport engines?
Why whouldnt everyone just get a TRD or other metal headgasket the same size? wouldnt that be perfect?
1.2mm uncompressed/1mm estimated compressed.
Check 7AFE gasket too (heard that they are 0.7mm).
12-12-2006, 04:25 AM
so a 1.5 mm Metal HG will be ok? so then instead of 9.5:1 id be approximately 9:1 comp with a 1.5mm?
With that thickness will i be OK for blowing a HG?
12-12-2006, 10:42 AM
Hoey, stolen thread warning Evil
You can run up to 0.6bar boost even with stock 9.4 CR on premium fuel.
04-04-2007, 07:49 PM
This is an old thread but i need to know waht's the thickness of the standard head gasket?
I need that to make the calculations about how much i must skim my engine's head to achieve the desired compression ratio.
I was thinking to increase until the 11:1? What do you think? Is it too much?
04-04-2007, 08:43 PM
im interested in this topic too.. from what i've read, the bigport engine has 7.56 mm lift and 1.2 mm headgasket.
what i want to know is how much does the cam timing change if you say use 0.5 mm headgasket and shave additional 0.5 mm from the head (making total of -1.2mm). Would you need adjustable cam sprockets in this case to make a positive torque gain and would this -1.2 mm drop make valves interfere with pistons?
and what sort of CR do the(MAP) bigport engines have 9.4 or 10.2 ??!
04-04-2007, 10:57 PM
I've measured now a new OEM gasket and it has 1,4 mm however when fitted the thickness will decrease obviously.
I think the std CR for the MAP bigport engine is 10:1 and i don't think that is necessary to fit adjustable sprockets if you reduce 1 mm.
04-05-2007, 12:52 AM
the MAP ae86 bluetop EUR engine has 10:1 .
The standard head gasket compressed has 1.0mm
if you want 11:1 you should shave 0,5mm your head and use a 0,5mm trd head gasket....
I have a JDM AE92 engine (9.4:1) and the head has been shaved 1.2mm and i'm using a 0,5mm trd head gasket.
I think I have something close to 11:1 now ....
Using 8.5mm cams th engine is now intrusive, it means that if the engine belt fails there will be a problem, but only if that happens... ( lots of engines have that problem in standard form)
04-05-2007, 09:59 AM
great info! but will there be any interferance if shaving total 1.2 mm and using stock cams (7.56 lift)?
04-05-2007, 11:00 AM
i'm not sure , but i think yes ......
try it yourselft Smile
04-07-2007, 03:28 AM
I would guess you might get away with that kind of shaving + metal head gasket.
A nice bottom end power would be defenately gained. But the raise in compression might wear those conrod bearings a little bit more.
Best regards
  Silvertop Headgasket? byd1380 3 5,522 01-05-2009 06:02 PM
Last Post: byd1380
  9.5mm lift camshafts with OEM followers... anyone? apardal 9 11,844 10-15-2008 03:24 PM
Last Post: robokill
  head skiming/size headgasket/hks f-con! nick 9 11,289 04-10-2008 06:17 PM
  will the 0.5 mm HEADGASKET clear? Apolan 15 17,826 01-31-2008 01:48 PM
Last Post: meshin
  5mm headgasket filh 14 15,616 01-28-2007 08:29 AM
Last Post: Plex
