about 5mm TRD headgasket
12-08-2006, 01:10 AM
As I'm rebuilding my old engine , i spoke about 5mm Trd headgasket to the machinist. he told me that with that gasket , pistons had to be worked on to avoid contact with valves .not at idle , but at high revs !
any experience about that?
And if so , there won't be much gain , as you get more space in combustion chamber by remachining the valves spaces on pistons?
Filh
Filh
Save the RWD cars
12-08-2006, 10:32 AM
Smallport engine ?
I'm interested in that too. Maybe your machinist can try clay test with dry build ? AFAIK there must be at least 1mm distance between piston and valve surfaces, preferably 1.5mm.
12-08-2006, 12:28 PM
You can run serius boost with a headgasket like that Smile
I know you mean 0,5mm
/Skassa
"""www.turbotoys.dk"""
12-08-2006, 02:21 PM
I have 0,5 mm head gasket and I shaved 0,5 mm to the head. No contact. I've heard people shaving 1,35mm to the head and still no contact.
Tell your machinist that no matter what happens to the drive belt, at stock setting the valves never hit the pistons. That gives you an idea of how big the space has to be.
With 0,5mm gasket and 0,5mm head shave, the valves still never hit the pistons.
Best regards
12-08-2006, 11:58 PM
apardal Wrote:I have 0,5 mm head gasket and I shaved 0,5 mm to the head. No contact.
How much is compresion ratio with 1 mm shaved ??
Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62
12-09-2006, 12:20 AM
Thanks , i'm a bit more confident now .
Maybe more critical with a high lift valve camshaft ?
to Jamiemirror :my engine is a bigport model .
Yes Denmark, sorry I meant 0,5mm . for sure with 5mm headgasket , no need to worry Banging head
filh
Filh
Save the RWD cars
12-09-2006, 12:33 AM
Are you speaking about the bigport or the smallport engine?
I have a smallport engine and I shaved -0,7mm with OEM head gasket, but now I'm thinking of trying a 0,5 or 0,8mm TRD one. Anyone has experience about this?
On the club4ag.com I read that -0,1mm of the headgasket will raise the comp.ratio by 0,1:1
12-09-2006, 09:18 PM
what is the stock thickness on the small and bigport engines?
Why whouldnt everyone just get a TRD or other metal headgasket the same size? wouldnt that be perfect?
12-10-2006, 11:02 PM
^^^ Can anyone answer this one? I am going to be purchasing a metal-headgasket when I turbo my corolla. Id like to keep my stock compressionbor even lower it slightly so I can run higher boost. stock preferably.
12-11-2006, 11:02 AM
Hoey, you'll need a thicker head gasket for a forced induction setup. 1,5mm I think.
Best regards
  Silvertop Headgasket? byd1380 3 4,897 01-05-2009 06:02 PM
Last Post: byd1380
  9.5mm lift camshafts with OEM followers... anyone? apardal 9 10,637 10-15-2008 03:24 PM
Last Post: robokill
  head skiming/size headgasket/hks f-con! nick 9 10,098 04-10-2008 06:17 PM
  will the 0.5 mm HEADGASKET clear? Apolan 15 16,009 01-31-2008 01:48 PM
Last Post: meshin
  5mm headgasket filh 14 13,930 01-28-2007 08:29 AM
Last Post: Plex
