Wierd Dyno result
05-05-2005, 09:52 AM
Wierd Dyno result
But you need to remove the oil pan. That means - engine out of the engine bay.
05-05-2005, 10:55 AM
Wierd Dyno result
Why take out the engine, when you can remove the oilpan with the engine in the bay? Confused
05-05-2005, 10:57 AM
Wierd Dyno result
Knudsen Wrote:Why take out the engine, when you can remove the oilpan with the engine in the bay? Confused
Can you ? I cannot.
05-05-2005, 11:00 AM
Wierd Dyno result
you cant Knudsen coz the engine stands on the front crossmember and not on tne chassis, which (crossmember) has to be removed if you want to remove the oil pan..
05-05-2005, 06:16 PM
Wierd Dyno result
Apolan Wrote:you cant Knudsen coz the engine stands on the front crossmember and not on tne chassis, which (crossmember) has to be removed if you want to remove the oil pan..
Really..... i cant.....?
MuHaHaHa.. Evil
The only thing you have to dismount, is the gearbox brackets on each side Wave
The enginemounts isnt attached to the oilpan :wink:
  Ignition advance, Dyno and Detonation apardal 10 19,803 04-21-2008 11:02 AM
Last Post: KrizKH
  Dyno proven header for AE86 ????? jondee86 10 18,435 03-27-2008 05:15 PM
Last Post: oldeskewltoy
  Rear oil strainer - 6 bolts - wierd feeling?! Apolan 7 9,148 02-26-2008 03:13 AM
Last Post: Apolan
  AE86 Dyno Results! Wraith 9 18,562 10-16-2006 09:13 AM
Last Post: Mux213
  Wierd and annoying rattling noise Knudsen 14 19,520 04-13-2005 01:24 PM
Last Post: Knudsen
