White Kouki Trueno Hatch, 20V BT, FC3S brake, Watanabe MG,
01-03-2011, 03:41 PM
Post: #31
some updates
honda stream brake booster ![]() ![]() ![]() ![]()
01-03-2011, 04:14 PM
Post: #32
some stuffs
redline tail light ![]() since the tail light rubber seal is in bad condition, I used rubber that was cut in shape instead ![]() ![]() Itavolanti Admiral steering (almost 30 yrs old but in mint condition ) ![]()
01-07-2011, 02:43 PM
Post: #33
Question: why did you use a Honda Stream brake booster?
Thanks
01-07-2011, 03:12 PM
Post: #34
Ozone Wrote:Question: why did you use a Honda Stream brake booster? Hi Because 1.its size is bigger than the OEM one ( 1.5 step) 2. it is the biggest size that can be fitted to hachi without hitting body 3. It can be fitted without any modification |
01-14-2011, 06:47 AM
Post: #35
redlines
![]() ![]() ![]() interior ![]() trd rear wing, just test fit
01-17-2011, 05:23 PM
Post: #36
Since ther was some member message to me about the water line of the engine,
I took the inlet and outlet of my engine here below ![]() If any mistake I would like to say sorry The maintained water outlet line ![]() The closed inlet line on the exhaust side. ![]() new inlet line at intake side
01-17-2011, 05:37 PM
Post: #37
Aluminum header adapter to adapt 4age bluetop header to 20v BT block
01-17-2011, 05:39 PM
Post: #38
TRD clutch and flywheel( which I think it is C-one motor sport 4.4kg )
01-24-2011, 04:09 PM
Post: #39
Thanks for the pictures. But have you also pictures of how you made the delco rebuild?
Nice work! Grtz... -------------------------------------------------------- Corolla GT AE86 rally ('87) .... Corolla GT AE86 rally/historic ('83) nog werk aan... Corolla GT AE86 in opbouw ('84) ... |
01-29-2011, 07:43 PM
Post: #40
another pics for engine
after modification the header adapter with waterline hole. ![]() ![]() ![]() another 4AG engine, this one is from this car, put it out, clean and change some essential parts such as timing belt, gasget, seal ETC. ![]() Watanabe MG with 195/50/15 BF-Goodrich G-force tire ![]()
| 1985 Toyota Sprinter Trueno GT APEX kouki from Japan | sheppardpat47 | 3 | 52 |
Today 06:06 PM Last Post: banpei |
| Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 19,726 |
| Adam's white, rusty levin...updated 23-09-2018!! | adomz | 150 | 179,447 |
09-23-2018 05:14 PM Last Post: adomz |
| 86er Levin Hatch from Germany | ArToAE86 | 19 | 21,047 |
01-24-2018 10:35 PM Last Post: ArToAE86 |
| Lauren's 1985 Kouki Trueno | Lauren | 161 | 219,505 |
09-01-2015 08:46 PM Last Post: Lauren |
![AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG, [Image: AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG,]](http://i477.photobucket.com/albums/rr140/asw3690/mini%20parts/IMG01725-20101222-1029.jpg)
![AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG, [Image: AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG,]](http://i477.photobucket.com/albums/rr140/asw3690/mini%20parts/IMG01726-20101222-1047.jpg)
![AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG, [Image: AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG,]](http://i477.photobucket.com/albums/rr140/asw3690/mini%20parts/IMG01726-20101222-1128.jpg)
![AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG, [Image: AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG,]](http://i477.photobucket.com/albums/rr140/asw3690/mini%20parts/IMG01728-20101222-1505.jpg)
![AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG, [Image: AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG,]](http://i477.photobucket.com/albums/rr140/asw3690/mini%20parts/IMG01736-20101229-2206.jpg)
![AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG, [Image: AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG,]](http://i477.photobucket.com/albums/rr140/asw3690/mini%20parts/IMG01741-20101229-2304.jpg)
![AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG, [Image: AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG,]](http://i477.photobucket.com/albums/rr140/asw3690/mini%20parts/IMG01737-20101229-2248.jpg)
![AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG, [Image: AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG,]](http://i477.photobucket.com/albums/rr140/asw3690/mini%20parts/IMG01754-20110102-1410.jpg)
![AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG, [Image: AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG,]](http://i477.photobucket.com/albums/rr140/asw3690/mini%20parts/IMG01756-20110102-1414.jpg)
![AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG, [Image: AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG,]](http://i477.photobucket.com/albums/rr140/asw3690/mini%20parts/IMG01757-20110102-1442.jpg)
![AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG, [Image: AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG,]](http://i477.photobucket.com/albums/rr140/asw3690/mini%20parts/IMG01819-20110116-0933.jpg)
![AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG, [Image: AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG,]](http://i477.photobucket.com/albums/rr140/asw3690/mini%20parts/IMG01817-20110116-0932.jpg)
![AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG, [Image: AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG,]](http://i477.photobucket.com/albums/rr140/asw3690/mini%20parts/IMG01880-20110123-2108.jpg)
![AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG, [Image: AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG,]](http://i477.photobucket.com/albums/rr140/asw3690/mini%20parts/IMG01882-20110125-1905.jpg)
![AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG, [Image: AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG,]](http://i477.photobucket.com/albums/rr140/asw3690/mini%20parts/IMG01881-20110125-1905.jpg)
![AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG, [Image: AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG,]](http://i477.photobucket.com/albums/rr140/asw3690/mini%20parts/IMG01846-20110119-1521.jpg)
![AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG, [Image: AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG,]](http://i477.photobucket.com/albums/rr140/asw3690/mini%20parts/IMG01890-20110127-1926.jpg)
