White Kouki Trueno Hatch, 20V BT, FC3S brake, Watanabe MG,
12-14-2010, 01:22 PM
Back to body work
12-14-2010, 01:44 PM
Here is my prepared front strut
![]() TEIN ball joint and spring JIC shock absorber RX7 FC3S 4 Pots disc and caliper ![]() ![]() and here is the rear one ![]() |
12-14-2010, 04:04 PM
Seats - is my DREAM!
![]() Which companies are shock absorbers? ![]() http://ae70.blogspot.com/ & http://drft.io.ua/ |
12-14-2010, 04:27 PM
DRFT Wrote:Seats - is my DREAM! Hi, The rear shock absorber Im not sure with brand but Kayaba was its maker, and spring also, it was light blue from japan before I repaint it so I guess it is TRD. I took this set from drift car in Japan ![]() for the front, as I said it is JIC shock absorber with tein spring |
12-15-2010, 06:35 AM
a little update
![]() ![]() ![]() and I will use this, 3M automix panel boonding, it just like a spot welding but no corrosion, a bit costly ![]() |
12-16-2010, 04:26 PM
To use 3M panel bonding
first all seal and color need to be removed. Then taped the area ![]() ![]() engine bay ![]() ![]() ![]() |
12-18-2010, 06:13 PM
painting interior
![]() first, base paint ![]() ![]() followed by enamel paint ![]() ![]() ![]() Then Lacquer ![]() ![]() ![]() |
12-18-2010, 06:18 PM
![]() Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
12-18-2010, 07:04 PM
Surface preparation for the real enamel paint
![]() ![]() in painting room ![]() ![]() ![]() |
12-18-2010, 07:08 PM
robokill Wrote: Hi, Thanks for comment ![]() for the bottom of the car, as I have checked it still in good condition so I think only rust preventing coat will be enough for this hachi, or do you have any suggestion for the bottom of the car? ![]() |
Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 17,440 |
Adam's white, rusty levin...updated 23-09-2018!! | adomz | 150 | 166,569 |
09-23-2018 05:14 PM Last Post: adomz |
86er Levin Hatch from Germany | ArToAE86 | 19 | 19,124 |
01-24-2018 10:35 PM Last Post: ArToAE86 |
Lauren's 1985 Kouki Trueno | Lauren | 161 | 207,056 |
09-01-2015 08:46 PM Last Post: Lauren |
OST-026: "My White Hatch" | oldeskewltoy | 49 | 64,172 |
07-03-2014 11:56 PM Last Post: oldeskewltoy |
