Which Camberplates do fit on Koni Yellow dampers?
06-16-2007, 06:05 PM
Post: #31
![]() ![]() ![]() TEIN: We can only supply M12 x P1.25 PMP03-91022-D list price GBP9.50 + vat each and M14xP1.5 PMP03-91022-2 list price GBP9.50 + vat each. Both in stock. just to get it all in one post! ![]() ![]() |
06-16-2007, 06:23 PM
Post: #32
I have a mail from tein uk and it says pmp03-91022-2 is the m12xp1,25
06-17-2007, 12:01 AM
Post: #33
TEIN must be a little cunfused.
well i orderd both and they worked out perfect. so if you order just give them the thread size. if they send you the wrong one they have to fix the problem ![]() ![]() |
06-17-2007, 04:18 PM
Post: #34
I have a similar question!!!!
I am thinking about this for some time now.... What to do?! Koni yellow AE86 at the rear- no doubts... But what for the front? If I take AE92 (short shocks) I have to do the coilovers... Also I am running 13'' rims... If I put AE92 and coilovers it is bye bye snow touge... It will be a race car for dry... How bad is it if I do AE86 Koni in front and back? I use my car everyday. Actualy, how important for drifting are the camberplates? What happens with the car in the drift without camber plates and with... Impressions? SNO-MO-BIRU project started- CHIRO |
06-17-2007, 04:35 PM
Post: #35
The koni suspensinion is nice, but with kaaz 2 way lsd you have much more understear then before, ill hope when i have my new tyres (hankook ventus rs02) and the camberplates to get a neutral setup.
06-17-2007, 05:34 PM
Post: #36
Quote:If I put AE92 and coilovers it is bye bye snow touge... It will be a race car for dry... Why ? |
06-17-2007, 05:40 PM
Post: #37
jamiemirror Wrote:Quote:If I put AE92 and coilovers it is bye bye snow touge... It will be a race car for dry... Way too low for our roads and snow .. 2 mrgud: I don't know why is such a problem to rebuild your front shocks, and make out of them winter setup. You have a par front struts more than you need, and just rebuild front shocks for cheap, and put samo spring on it (or make ones cheap)... for winter you don't need more than that. And because of Global Warming the snow isn't falling as it use to... ![]() Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
06-17-2007, 08:05 PM
Post: #38
But meshin, coilovers mean that you can adjust the height.
Also no problem to build AE86 setup with AE92 shocks and keep original height. |
06-17-2007, 11:06 PM
Post: #39
Just as a brainfart and to cause grief(
![]() Has anyone ever considered the NEWLY available HTS112?? Many folks here may have heard of the HTS102 short strokes, but HTS also has a "normal" stroke version for the AE86... The HTS is now called the D-Spec The HTS112 http://www.hitachi-hap-la.com/TokicoGasS...pp/28.html http://www.hitachi-hap-la.com/TokicoGasS...cts/dspec/ I built my suspension closer to European road conditions then southern Cally road conditions... I had lived in northeastern Pa... VERY cold temps... heaving roads... need full ride height.... My car rides at full ride height thanks to custom wound springs. I currently am running the long gone Illuminas. ![]() About 2 years ago there was a "scare" that the HTS were going away so I bought a set... Needless to say that was only half true... they are no longer available in Japan... but the US market has them available. Once my Illuminas dye, the HTS's will be used. Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
06-18-2007, 03:44 PM
Post: #40
Than it's decided... Coilovers...
Ordered shocks a few seconds ago... ![]() SNO-MO-BIRU project started- CHIRO |
20v BT - which oil pump? | Mylesmck | 4 | 4,172 |
Mistlamps don't fit | gh0st | 1 | 2,951 |
10-14-2021 09:00 PM Last Post: banpei |
Can you identify this wheels? Will they fit AE86? | Ryo | 8 | 12,739 |
KONI Sports shocks for the AE86... | jondee86 | 11 | 23,406 |
Rim width. Which is best.... | Dino86 | 5 | 8,034 |
