Where to buy new master and slave clutch cylinders?
06-26-2013, 10:51 PM
As the title says. Been looking for days now without any particular luck. Fensport is out of stock, the Ebay (.com, .se, .de, .au) stuff I've come across either doesn't look right or don't ship to Sweden. Found some really promising stuff at a US site but they wanted €135 in shipping and handling! :O
Could someone please point me in the right direction? Dumb question
06-26-2013, 11:49 PM
Toyota will sell you a good repairkit for both Smile
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
06-27-2013, 07:57 AM
Do you have any numbers on them? Also do you know if they come with new rods and everything?
06-27-2013, 08:53 AM
I wouldnt go for a repair kit if you can buy new parts for cheap.
I once paid 100 euro's for a toyota master brake cylinder repair kit, and I later bought 2 brand new (refurbished) ones for 20 dollars.. go figure (that was a lucky find though).
Try teilesuche24 (they also have an internation site searchpart24 or something like that):
http://www.teilesuche24.de/toyota/coroll...ung-100079
They are a reliable store in my experience. As with ALL online store part purchases, YOU need to make sure the part you order is the correct one. Check the part numbers and possible reference numbers and google them, if they are correct they should either be referenced to the OEM partnr, or at least be mentioned as fitting an AE86 on the manufacturers site.
06-27-2013, 12:17 PM
Ive never had luck with the slave cylinders and always ended up using the repair kits for them, cause the new ones you buy will have the bleeding nipple in the wrong place in 8 out of 10 times Smile
06-27-2013, 07:57 PM
Thanks Ivan that was exactly what I was looking for! Smile. With those prices I can't be bothered to rebuild.
Fax: That's why you take pictures to compare with the parts you have Wink
EDIT: It was seekpart24, they have a language option in the top right corner.
EDIT#2: Seekpart24 didn't have the slave cylinder (despite it being on the website) and the master cylinder would take forever to get in stock Sad. But! I found AutohausAZ.com. Got me AISIN master and slave for 47$(!) and shipping was dirt cheap as well Smile
  Bigger brake master cylinder options Koen 10 2,370 01-08-2026 03:12 PM
Last Post: r.ave
  Clutch and brake cylinders MIGGZFSU 4 7,357 10-14-2017 07:52 PM
Last Post: MIGGZFSU
  Brake advice - master cylinder mannix20vt 12 18,936 08-21-2017 03:21 PM
Last Post: Project D
  Correct connection brake master cylinder? bozu 5 9,519 07-26-2015 12:28 PM
Last Post: bozu
  Dimensions clutch master cylinder bozu 2 7,799 04-16-2015 07:11 AM
Last Post: bozu
