Wheels, dimensions, offset and so on
12-01-2006, 01:56 AM
Post: #31
Amigaguy, what size tires did you end up buying?
[Image: AEU86 AE86 - Wheels, dimensions, offset and so on]
Koukis - Red, Silver/Gray,
12-01-2006, 02:35 AM
Post: #32
dAYTONA Wrote:Amigaguy, what size tires did you end up buying?
I went for 6x14 rims with 175/65-R14 tires.
12-01-2006, 11:34 AM
Post: #33
apardal Wrote:I'm running 15x7 offset 0 and I've had my caster aligned all the way to the front. No rubbing at the back. Rubs a little in the fender lip though. Plastic covers still there.
Best regards
Apardal, could you please give me your alignment numbers? How may degrees is all the way?
  Quick question - Brake Pad Dimensions Lt86 2 7,294 06-07-2015 12:08 AM
Last Post: jondee86
  Dimensions clutch master cylinder bozu 2 8,383 04-16-2015 07:11 AM
Last Post: bozu
  Billet 5X114.3 hubs adds 30mm offset 4000GT 0 4,859 01-30-2015 06:40 AM
Last Post: 4000GT
  Spindle dimensions, backing plate bolt pattern Rascal21 18 29,725 03-13-2014 11:45 AM
Last Post: Rascal21
  DRAG dr54 wheels >> +15 offset >? help !! geoscranny84 4 7,787 04-26-2012 09:31 PM
Last Post: bozu
