Wheel studs
01-22-2007, 08:44 PM
Wheel studs
This is an "up" for this old topic.
I want to buy longer wheel studs for my hachi and I made a search on ebay. They sell only for the S13, some Hondas and Nissans...at least I haven't found more. They say different sizes for them like 12x1,25 and 12x1,5, regarding Ivan's post, the 1,5 is the stock pitch for the hachi? And how long studs should I buy if I plan to use some 2cm spacers and which "head" shape will fit the hachi? 1987 Toyota Corolla GT coupe - for holidays oversteer 2005 Toyota Corolla - for daily understeer |
01-22-2007, 10:25 PM
Wheel studs
If i want to use 7mm spacers i dont need longer studs?
01-22-2007, 11:23 PM
Wheel studs
We tried with 6mm spacers and studs were long enough. Depends of rims.
8mm spacers were too thick for stock studs. I can find +5mm longer studs locally. But not any longer than that. |
01-23-2007, 12:02 AM
Wheel studs
For my supra celica rims
01-23-2007, 11:47 AM
Wheel studs
6mm will work.
7mm - possible but I will not use them. PS: the Supra rims have good offset and are wide - why you need to use spacers ??? |
01-23-2007, 12:13 PM
Wheel studs
Does anybody know the answer for my question as well? See 4 posts upper.
01-23-2007, 01:09 PM
Wheel studs
SutteR, I have hub off the car (spare), will remove stock stud and measure the slotted part diameter(the part which is pressed on the hub).
Will measure the length too and calculate your desired length. |
01-23-2007, 01:23 PM
Wheel studs
May thanks in advance jamie!
(What about the roll cage? Sent a PM yesterday.) 1987 Toyota Corolla GT coupe - for holidays oversteer 2005 Toyota Corolla - for daily understeer |
01-23-2007, 01:24 PM
Wheel studs
offtopic:
read the PM, waiting the owner (I'm not the owner - the car+cage belongs to my friend here) to decide. |
12-20-2007, 10:28 PM
Wheel studs
Will the LandCruiser studs work without spacers? I need to find some long studs for my coupe and they seem to be nearly impossible to find, esp. since toyota stopped selling them in dealerships. =/
I have also heard that 4runner studs work for hachis... is that right? AJC '85 GTS coupe - ghetto and half broken | '86 SR5 hatch - soon to be swapped & caged My Website My Myspace |
| Spare wheel & spare wheel carrier | ondafly | 6 | 1,678 |
01-19-2026 01:00 PM Last Post: ondafly |
| ARP Head studs in a N/A engine, necessary? | Jimmi The Kid | 13 | 19,644 |
02-04-2013 11:27 PM Last Post: Jimmi The Kid |
| Longer studs | Eric | 4 | 7,915 |
04-29-2011 07:35 AM Last Post: Eric |
| longer wheel studs | fax0815 | 8 | 13,524 |
02-17-2011 09:57 AM Last Post: max_ae86 |
| How to fit rear wheel studs without removing the shafts? | Slipangle | 3 | 6,834 |
11-19-2010 10:29 PM Last Post: Slipangle |
