Whats the biggest cams for the 4AG?
04-02-2005, 11:00 PM
Hmmz i had a talk with bill then in the car i asked him if the engine and ecu would take the following setup
81.5 bore 272 cams in en ex portet head adjustable cam pullies he sayd i should be able to pull it of on standard ecu and making around 150-160 hp in the engine. so that would be a nice 130 on the wheels with luck Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
04-13-2005, 08:13 PM
and what about difference between intake and exaust cams duration .JonT
you've a set with both I and E 264°, but as there's a lot of choice as the intake and exaust cams are separated. What's the best . I 'd like to change cams , but keeping stock ecu , and fitting 250cc injector. I don't expect to have a lot of hp , as I'm realist . Fil Filh Save the RWD cars |
04-14-2005, 07:50 AM
I actually have a 256, 264 combination with 8.1 lift. I'm not really an engine expertr and there is a degree of following the crowd with these. A few of the Japanese tuning mags seem to recommend this combination plus i was speaking to a few people and was told it worked well. As for setting them up, i'll need to find out myself when the time comes.
04-14-2005, 01:07 PM
NoHachi is right. But:
1. You can try wild cams and/or ITB with VAC buffer (a little box buffering the vacuum). 2. You can tweak MAP signal (dont exactly need to buy HKS, Blitz or Apex'i stuff). 3. You can try coolant sensor tweak. There is a little funny mod (especially for ITBs) - the coolant sensor is tweaked only when ECU sends TVIS signal. 4. You can try adjustable FPR. Of even better - raising rate FPR. 5. You can upgrade injectors (as filh mentioned). |
04-14-2005, 01:12 PM
Hey Jammie send us instructions how to do these tweaky things and upgrades...
AE86 FANATIC!!! |
04-14-2005, 01:17 PM
Oh no ;-)
alimonos, I'm not a tunning guru - just try this or that in order to make things to work. There is no 100% solution (except aftermarket ECU) - I think. In fact I prefer to be mechanic instead of driver - this is somewhat freak :-) |
04-14-2005, 01:22 PM
Understood Jammie... :wink:
AE86 FANATIC!!! |
04-14-2005, 01:50 PM
ΟΚ Jammie! And I prefer to drive instead of mechanical stuff. How about a team?
04-14-2005, 01:56 PM
Dorito, how about the sponsor ?
04-14-2005, 01:58 PM
hehe aeu86.org of course!
| Question about 4AG 20v Engine Block | CHACAMAN | 1 | 2,966 |
| Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 16,708 |
| Shim size for AM cams | kazi | 4 | 7,084 |
| whats the crack with 16v turbo? | kazi | 5 | 8,370 |
08-02-2017 12:15 AM Last Post: kazi |
| Toda Cams | Alex170984 | 7 | 11,076 |
02-11-2017 05:50 PM Last Post: Alex170984 |
