Whats the biggest cams for the 4AG?
04-02-2005, 11:00 PM
Hmmz i had a talk with bill then in the car i asked him if the engine and ecu would take the following setup
81.5 bore
272 cams in en ex
portet head
adjustable cam pullies
he sayd i should be able to pull it of on standard ecu and making around 150-160 hp in the engine.
so that would be a nice 130 on the wheels with luck
04-13-2005, 08:13 PM
and what about difference between intake and exaust cams duration .JonT
you've a set with both I and E 264°, but as there's a lot of choice
as the intake and exaust cams are separated. What's the best .
I 'd like to change cams , but keeping stock ecu , and fitting 250cc injector.
I don't expect to have a lot of hp , as I'm realist .
Fil
Filh
Save the RWD cars
04-14-2005, 07:50 AM
I actually have a 256, 264 combination with 8.1 lift. I'm not really an engine expertr and there is a degree of following the crowd with these. A few of the Japanese tuning mags seem to recommend this combination plus i was speaking to a few people and was told it worked well. As for setting them up, i'll need to find out myself when the time comes.
[Image: AEU86 AE86 - Whats the biggest cams for the 4AG?]
04-14-2005, 01:07 PM
NoHachi is right. But:
1. You can try wild cams and/or ITB with VAC buffer (a little box buffering the vacuum).
2. You can tweak MAP signal (dont exactly need to buy HKS, Blitz or Apex'i stuff).
3. You can try coolant sensor tweak. There is a little funny mod (especially for ITBs) - the coolant sensor is tweaked only when ECU sends TVIS signal.
4. You can try adjustable FPR. Of even better - raising rate FPR.
5. You can upgrade injectors (as filh mentioned).
04-14-2005, 01:12 PM
Hey Jammie send us instructions how to do these tweaky things and upgrades... Respect!
04-14-2005, 01:17 PM
Oh no ;-)
alimonos, I'm not a tunning guru - just try this or that in order to make things to work. There is no 100% solution (except aftermarket ECU) - I think.
In fact I prefer to be mechanic instead of driver - this is somewhat freak :-)
04-14-2005, 01:22 PM
Understood Jammie... :wink:
04-14-2005, 01:50 PM
ΟΚ Jammie! And I prefer to drive instead of mechanical stuff. How about a team? Smile
04-14-2005, 01:56 PM
Dorito, how about the sponsor ? Wave
04-14-2005, 01:58 PM
hehe aeu86.org of course!
  Question about 4AG 20v Engine Block CHACAMAN 1 2,629 06-10-2022 05:17 PM
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 15,219 02-10-2020 06:39 PM
Last Post: Power_uP
  Shim size for AM cams kazi 4 6,600 12-18-2017 05:34 PM
  whats the crack with 16v turbo? kazi 5 7,798 08-02-2017 12:15 AM
Last Post: kazi
  Toda Cams Alex170984 7 10,450 02-11-2017 05:50 PM
Last Post: Alex170984
