What spring on KE70 ?
04-15-2009, 06:23 PM
Post: #31
i cannot think of any reason why that wouldnot fit.
i just changed form ke79 axle to ae86 axle, and that was a straight bolt on with all parts that are already on the car. springs, dampers, etc. zo i guess coilovers should fit too. |
04-15-2009, 07:58 PM
Post: #32
at the rear ?
I checked all the rear axles i have and i cannot find why i can not as well Thanks Eric |
06-15-2009, 05:06 PM
Post: #33
ok so i finally did the following
- 1982 ke70 struts - 1979 tophats - Meganracing AE86 springs -6cm nothing else to change and it is perfect Thanks for the help |
| SOME 4AG valve spring specs | oldeskewltoy | 5 | 16,772 |
05-04-2015 01:17 PM Last Post: Project D |
| clutch pedal return spring | Eifelaner | 2 | 9,346 |
09-06-2013 10:21 AM Last Post: Apsogos |
| P-valve CLOSED --> Stiffer spring will do it :) | Dino86 | 1 | 4,650 |
04-05-2012 04:17 PM Last Post: Dino86 |
| lowering spring information HELP | martyg | 1 | 4,596 |
09-27-2011 01:56 PM Last Post: martyg |
| clutches and spring washers position in 2 Way TRD diff???? | T_AE86 | 3 | 7,008 |
09-01-2011 10:50 AM Last Post: T_AE86 |
