What radiator to use??
06-03-2007, 02:35 AM
my dad came with a question, would the original AE86 radiator work for the 20 valve silvertop?
06-03-2007, 04:47 PM
I too have the SV21 Camry twin core, see here:
http://www.ae86drivingclub.com.au/forum/...l=radiator |
06-03-2007, 05:24 PM
evfan42 Wrote:my dad came with a question, would the original AE86 radiator work for the 20 valve silvertop? Jup, it will. A wheel to steer the front of the car A pedal to steer the rear |
06-03-2007, 11:07 PM
Little remark about the rx-7 SA radiators: they seem to need bigger diameter piping than the stock radiator, so fitting them is not nearly plug and play.
I would just opt for a new ae86 radiator.. it can handle regular use of a 4age very efficiently. FABRICA MI DIEM, PVNC! |
06-04-2007, 04:42 AM
NoHachi Wrote:evfan42 Wrote:my dad came with a question, would the original AE86 radiator work for the 20 valve silvertop? alright thanks no hachi |
06-05-2007, 09:47 PM
oldskull Wrote:I need new one too soon, mine still leak... Heey Oldskull! Mijn radiator is ook zo lek als een zeef. Ik ben ga een dezer dagen naar een leverancier. Ik kan korting vragen als we samen bestellen? EDIT: oeps dit moest een pm zijn 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
07-09-2007, 01:49 PM
Would a Mk2 Golf/Jetta radiator work??
07-09-2007, 06:11 PM
It has been done before...but it requires some fiddling with a pressure tank.
07-09-2007, 06:59 PM
hachirokuGTV Wrote:Would a Mk2 Golf/Jetta radiator work??Yes, it would work
07-09-2007, 07:41 PM
evfan42 Wrote:my dad came with a question, would the original AE86 radiator work for the 20 valve silvertop? It will but you have to either run the water lines across the back of the head or over the header and across the front of the head to get them to work. You can use an early 80's Corolla radiator that has both openings on the right side (when looking from the front of the engine bay) as opposed to the openings both on the left as with the original AE86 layout. I have a Koyo in my car. It's OK. I'm currently having a high driving temperature, but I'm suspecting the thermostat to be the culprit. I'm working with Sym from Pass Racing on locating a low temp unit for me. ![]() Peter Diaz http://www.shiftgearclothing.com http://www.ectoyotas.com/forum/ http://www.facebook.com/elfatherae86 |
| Radiator & grill support panel (Levin) | FanIsHere | 5 | 4,360 |
11-14-2022 10:07 PM Last Post: Ivan141 |
| Alu thick core radiator fitment | Gtsi-R | 5 | 5,112 |
01-26-2022 01:28 PM Last Post: Gtsi-R |
| AE86 F20C swap - Radiator issue | mad.matt | 3 | 7,837 |
02-07-2018 05:14 PM Last Post: mad.matt |
| Radiator oem or upgrade on racecar? | Jimmi The Kid | 5 | 7,880 |
| cool lower radiator hose | thanos | 4 | 7,575 |
![AEU86 AE86 - What radiator to use?? [Image: AEU86 AE86 - What radiator to use??]](http://img15.imageshack.us/img15/5796/tomstwincam1.jpg)
