What is this? + Oil temp sensor location
05-28-2012, 06:23 PM
Hello,
I'm wandering what's the purpose of plug in the red circle?
And more important... can it be used for a oil temp sensor?
It also has a hole (around 8mm?) at the area of the yellow arrow.
I read in another topic that the oil temp sensor can be installed via the plug in the blue circle also but there was some rare threadsize or something.
Thanks a lot for the info.
05-28-2012, 06:31 PM
No!!!
That´t the coolant draining plug for the block.
Why don´t you run a t-piece from the port where the original pressure sender sits? IIRC the thread is 1/8 NPT
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
05-28-2012, 08:13 PM
I guess that's the best option since the other one doesn't even have oil behind it...
I'm affraid I ran my engine oil to hot this weekend.
I installed sumpguard (alloy) so now there is no cooling on the sump from underneath (cooling wind)
Anyone nows the effect on the oil temperature with a sumpguard installed. I drove sporty, but not pushing hard (no track, no race)? Oilcooler is standard.
Engine consumed almost 1l over +-600km. Normally it's much less
Confused Confused
Does high oil temp (= high temp. on bearings etc..) kill the Engine directly or over longer time only...
Hope the E/G is not F*cked Sad Sad Sad Sad Sad
I didn't hear or feel anything strange...
05-28-2012, 09:45 PM
You just worry to much, I don´t see a sumpguard effecting the cooling that much.
Its hard to get oil temperature past 120deg with normal driving...
Much more important, mileage on you engine? What oil are you running?
05-29-2012, 06:36 AM
fax0815 Wrote:IIRC the thread is 1/8 NPT
WRONG !!!
It's 1/8 PT (or BSPT, it's the same thing)
NPT is an US norm, absolutely NOT the same thing !
BSPT = British Standard Pipe Tapered
NPT= National Pipe Thread Tapered
05-29-2012, 08:32 AM
Thanks to all,
No worries about correct thread size I will take the sensor to the shop anyway. I will post the final correct answer :wink:
@fax0815
I know my engine is not that fresh anymore (almost 200.000km).
I run 10W40 Kroon-oil Emperol.
But consumption is [u:dd02500c18]suddenly[/u:dd02500c18] high and just after I installed the alloy sumpguard. That's why I was wandering about oil temp.
Anyway I bought temp gauge already so I will continue installation.
05-29-2012, 06:40 PM
WRONG !!!
Sorry, just remembered when I fitted my defi gauges, I had the same problem, but you´re right its bspt, cause the defi sender bolted straight to the block Wink
Big Grin map sensor cheating? fdsjakl890 8 2,231 08-26-2025 01:12 PM
  Lambda sensor wiring sam3007 10 7,638 05-23-2022 10:00 PM
Last Post: The Doctor
  Placement location fuel filter bozu 0 4,442 12-01-2016 11:06 AM
Last Post: bozu
  trans oil, lsd oil change Apolan 9 20,486 10-01-2014 03:57 PM
  AE86 Engine Coolant Temp Sensor izanagi 8 23,228 09-06-2014 05:47 PM
Last Post: izanagi
