What dumpers on Coilovers
06-08-2005, 11:26 AM
So, soon I will need 2 install coilovers from paradiseracing on some new dumpers:
sugestions? I know that mostlly people use yellow KONI, buth for MR2 I ordered KYB AGX so because it must be for AE92 can it allso be from KYB?
06-08-2005, 11:35 AM
Just be carefull (we discussed this with Kristian) - short stroke coils & short stroke dumpers.
06-08-2005, 12:30 PM
i don't know why not... if they are short stroke..
how much for Koni, and how much for KYB?? |
06-08-2005, 12:38 PM
problem is that for AE92 there is AGX model for 86 not, so if on rear must be 86 model AGX can't be and that is only adjustable KYB model
06-08-2005, 05:51 PM
Could you please explain which dampers you want and for what car?
If your using them for your ae86 then there are SW20 and Camaro KYB AGX dampers that will work. FABRICA MI DIEM, PVNC! |
06-08-2005, 06:53 PM
well I'm looking for KYB for AE86 because I ordered allready 4 mine MR2 same model I will like to hawe same model on AE86. By using coil overs I must put shorter, so if you say that for SW20 is same I can order one more same set for AE86?
06-08-2005, 07:10 PM
No, you need sw20 front and chevy camaro rears if I'm not mistaken. The exact types are unknown to me but they are probably on club4ag if you do a search on "ae86 AGX" for example.
06-09-2005, 07:24 AM
yeap Ivan you say correct: front SW20 rear Camaro
| Carina drivers! - Coilovers for a TA60/62 | nyberrg | 2 | 7,871 |
06-05-2017 10:03 AM Last Post: nyberrg |
| Fitting driftworks CS2 coilovers | bozu | 2 | 6,077 |
05-30-2017 10:50 AM Last Post: bozu |
| D2 Coilovers any good? | heshan | 18 | 31,796 |
04-04-2017 02:40 AM Last Post: hachirokkos |
| Has anyone tried BC Racing coilovers? | AlexKTM | 9 | 15,097 |
09-05-2016 12:28 PM Last Post: mad.matt |
| Anyone running DIY Coilovers? | Rasteirinho | 8 | 16,072 |
11-19-2013 10:30 PM Last Post: totta Crolla |
