What brakes are you using ?
07-22-2005, 10:21 AM
Post: #31
I think these c-class discs will be acceptible :-)
What is their offset ?
If the cooling is the issue - try brake ducts with your original discs ?
Thicker disc is better in cooling also - the diameter is not so important.
07-22-2005, 10:26 AM
Post: #32
The offset is if i measure it correct 22mm.
That is if you place the disc on the tabe,and measure from the table and up to the dics.
If it to the midle,it´s 33mm
Skassa
"""www.turbotoys.dk"""
07-22-2005, 10:27 AM
Post: #33
They are only 27euro brand new from the MB dealer,
SO it´s a really cheap disc
07-22-2005, 10:29 AM
Post: #34
Safe offset, fine!
Only 27EU? At the Mercedes dealer?
Could be more specific about the c-class model then ? :wink:
PS: data from catalogue - AE86 fronts offset 38mm, c-class 43mm. Strange, but even in this case they are acceptable (I try to use Prelude ones with 51mm offset - if I trust to my catalogue, and they are acceptable too).
07-22-2005, 10:38 AM
Post: #35
It´s almoost the same disc on all the w202 model c-class.
The part number is:202 421 09 12,then you can check the price in your contry
regards,
Skassa
07-22-2005, 10:41 AM
Post: #36
Thanks man !
The C180 uses solid front discs ! WOW ! Huh
But the rest are just fine. Thanks again !
07-22-2005, 10:44 AM
Post: #37
Okay ,43mm is when i place it on the table and measure the full height
skassa
07-22-2005, 11:30 AM
Post: #38
There is a cheaper disc,the same ,but with 44mm offset.
Part number 124 421 16 12
regards,
Skassa
07-22-2005, 02:45 PM
Post: #39
JonT Wrote:Pictures of the EG6 kit, 25,000 Yen
I do like the EG6 kit, simple - and cheap (25000Yen=185Euro)
07-22-2005, 02:55 PM
Post: #40
185 if you live in Japan. Probably more like 300-350E to get it here.
Broken down 1984 Trueno HB
[Image: AEU86 AE86 - What brakes are you using ?]
  Rear brakes overheating Blaze0010 3 1,315 10-03-2025 05:57 PM
  Rear brakes totta Crolla 0 1,980 02-03-2023 12:54 PM
Last Post: totta Crolla
  Switching diffs for disc brakes? trippin 6 5,623 07-08-2022 03:35 AM
Last Post: trippin
  What suspension set up are people using? kazi 8 11,152 07-06-2017 05:26 AM
Last Post: headrush
  Rebuild rear disc brakes toyota crown ms112 axle bozu 0 5,019 12-21-2016 09:37 PM
Last Post: bozu
