WTF is that? speedodrive sender adaptor thingy....
12-04-2012, 12:41 AM
Hi,
recently took this of an import AE86, was fitted between the speedo output on the gearbox and the speedo cable going to the dash. Unfortunatly no partnumber or anything on it, the wires are in Toyota colours (black red dots, green red dots, red) but the plug doesnt look like anything I´ve seen on a toyota before.
Its not a converter, 1 turn on the input causes 1 on the output.
What could it be?
The car was a late GT APEX so I asume it might have had a digidash, but the digital speedsensors on google look different.
Any ideas? Dumb question
[Image: AEU86 AE86 - WTF is that? speedodrive se...thingy....]
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
12-04-2012, 12:49 AM
I think it's a a digital send sensor.
It give you the ability to have a digital signal and keeping the cable for the dash.
(Useful for people who want to hook up correctly a 20v ecu for exemple Wink )
12-04-2012, 10:19 AM
It ain't for AE86 digital cluster, that one uses cable, as analague one.
12-04-2012, 11:09 AM
Looks like a Terratrip sensor to connect rally - tripmaster.
I used one also in between the speedo cable before (different type but similar layout)
Now I use speedsensor on the front wheel.
12-04-2012, 03:21 PM
Certainly a mix between:
Terratrip speed probe:
and
Toyota sensor:
Anyway it must be used to get a digital speed signal (aftermarket dash, tripmaster, ECU...)
12-18-2012, 02:34 AM
Thanks for your help guys Wink
I´ll keep it, might come in handy some day...
09-11-2015, 05:23 PM (This post was last modified: 09-11-2015 05:24 PM by pack.)
fax still have that part? I need it! Smile
It is a Speed sensor splitter!
It gives the digital dash a mechanical speed sensor analog output and also gives the ecu the digital output! Smile
Regards
Regards
09-12-2015, 10:35 AM (This post was last modified: 09-12-2015 10:35 AM by totta Crolla.)
It is a sensor for a tripmeter, hall effect I think. Here are some details and they can be bought new from Brantz. I use one for a Brantz tripmeter and the hole for the speedo cable in the crossmember needs to be made larger.
http://www.brantz.co.uk/PDFs/Japanese%20...%20BR3.pdf
09-14-2015, 12:16 PM
Bought one from Brantz! But solved my Engine light error! Smile
hahah
  How to: Repair low fuel warning sender Sanity Clause 3 40,454 05-19-2025 11:05 PM
Last Post: Sanity Clause
  Water Temperature Instrument not moving - Sender Gauge Hama86 8 10,141 12-06-2017 06:48 PM
  Original gauge with universal fuel sender Komba 4 7,835 01-05-2015 03:27 PM
Last Post: Komba
  T3 rack adaptor bushing TheGerman 4 7,692 03-09-2012 12:32 AM
Last Post: TheGerman
  AE86 Temperature gauge sender thread? 4AGE FORD 1 4,567 03-20-2011 01:25 AM
Last Post: 4AGE FORD
