WTF is that? speedodrive sender adaptor thingy....
12-04-2012, 12:41 AM
Hi,
recently took this of an import AE86, was fitted between the speedo output on the gearbox and the speedo cable going to the dash. Unfortunatly no partnumber or anything on it, the wires are in Toyota colours (black red dots, green red dots, red) but the plug doesnt look like anything I´ve seen on a toyota before. Its not a converter, 1 turn on the input causes 1 on the output. What could it be? The car was a late GT APEX so I asume it might have had a digidash, but the digital speedsensors on google look different. Any ideas?
12-04-2012, 12:49 AM
I think it's a a digital send sensor.
It give you the ability to have a digital signal and keeping the cable for the dash. (Useful for people who want to hook up correctly a 20v ecu for exemple )
12-04-2012, 10:19 AM
It ain't for AE86 digital cluster, that one uses cable, as analague one.
12-04-2012, 11:09 AM
Looks like a Terratrip sensor to connect rally - tripmaster.
I used one also in between the speedo cable before (different type but similar layout) Now I use speedsensor on the front wheel. |
12-04-2012, 03:21 PM
Certainly a mix between:
Terratrip speed probe: ![]() and Toyota sensor: ![]() Anyway it must be used to get a digital speed signal (aftermarket dash, tripmaster, ECU...) |
12-18-2012, 02:34 AM
Thanks for your help guys
![]() I´ll keep it, might come in handy some day... 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
09-11-2015, 05:23 PM
(This post was last modified: 09-11-2015 05:24 PM by pack.)
fax still have that part? I need it!
![]() It is a Speed sensor splitter! It gives the digital dash a mechanical speed sensor analog output and also gives the ecu the digital output! ![]() Regards Regards |
09-12-2015, 10:35 AM
(This post was last modified: 09-12-2015 10:35 AM by totta Crolla.)
It is a sensor for a tripmeter, hall effect I think. Here are some details and they can be bought new from Brantz. I use one for a Brantz tripmeter and the hole for the speedo cable in the crossmember needs to be made larger.
http://www.brantz.co.uk/PDFs/Japanese%20...%20BR3.pdf An analogue brain in a digital World |
09-14-2015, 12:16 PM
Bought one from Brantz! But solved my Engine light error!
![]() hahah |
| How to: Repair low fuel warning sender | Sanity Clause | 3 | 40,437 |
05-19-2025 11:05 PM Last Post: Sanity Clause |
| Water Temperature Instrument not moving - Sender Gauge | Hama86 | 8 | 10,113 |
12-06-2017 06:48 PM Last Post: Bean |
| Original gauge with universal fuel sender | Komba | 4 | 7,825 |
01-05-2015 03:27 PM Last Post: Komba |
| T3 rack adaptor bushing | TheGerman | 4 | 7,679 |
03-09-2012 12:32 AM Last Post: TheGerman |
| AE86 Temperature gauge sender thread? | 4AGE FORD | 1 | 4,560 |
03-20-2011 01:25 AM Last Post: 4AGE FORD |
![AEU86 AE86 - WTF is that? speedodrive se...thingy.... [Image: AEU86 AE86 - WTF is that? speedodrive se...thingy....]](http://www.abload.de/img/dscn8932q5ppj.jpg)
![AEU86 AE86 - WTF is that? speedodrive se...thingy.... [Image: AEU86 AE86 - WTF is that? speedodrive se...thingy....]](http://www.rallynuts.com/user/products/large/T007_lge.jpg)
![AEU86 AE86 - WTF is that? speedodrive se...thingy.... [Image: AEU86 AE86 - WTF is that? speedodrive se...thingy....]](http://www.pakwheels.com/forums/attachments/d-i-y-projects/54109d1347255734-digital-speedometer-02032010446.jpg)
