WILDER CAMS SETTINGS????
07-08-2005, 11:20 PM
Hey guys i want help!!! Crying
Today I put (in the marks of the OEM cams) a pair of Kamakazee KK101 cams ( The duration is 262 with 8.9mm of lift) and my problem is that the engine can't run idle but really gets wild after 4800-5000 to 8000 !
I have the APEXi SAFC connected but don't know exactly what settings to use...
ANy suggestions???
07-08-2005, 11:23 PM
The idle problem is probably caused by the bad map sensor signal...you could try to make something to improve the vacuum signal to the MAP sensor (vacuum canister I think it's called).
07-08-2005, 11:26 PM
Could u be more specific Ivan??? Confused
07-08-2005, 11:42 PM
Wilder cams usually create less vacuum at idle speeds due to the larger overlap and opening times. Your map sensor doesnt get enough signal to properly determine fuel mixtures at idle, hence bad idle. But you could also just try increasing idle speed a bit first, see where that takes you..
07-08-2005, 11:48 PM
Ivan141 Wrote:Wilder cams usually create less vacuum at idle speeds due to the larger overlap and opening times. Your map sensor doesnt get enough signal to properly determine fuel mixtures at idle, hence bad idle. But you could also just try increasing idle speed a bit first, see where that takes you..
Ivan - we also need to know if he uses an MAP - or an AFM ?
07-08-2005, 11:51 PM
I 've got a map one Kristian.
I tried to increase idle speed by the screw in front of the TPS sensor but nothing... Dumb question
07-08-2005, 11:52 PM
Only swiss ae86's have AFM right?
Anyway, adjusting the idle fuel mixture is also an option..
07-08-2005, 11:53 PM
How to do that Ivan?
07-09-2005, 04:40 PM
Any help??? Crying Crying Crying
07-09-2005, 11:52 PM
Anybody help???
  Shim size for AM cams kazi 4 8,260 12-18-2017 05:34 PM
  Torque settings kazi 4 11,462 03-28-2017 12:15 AM
Last Post: kazi
  Toda Cams Alex170984 7 12,643 02-11-2017 05:50 PM
Last Post: Alex170984
  20V cams - CATCAMS vs KELFORD? Grant 19 48,687 11-19-2015 07:45 AM
Last Post: hachirokkos
  cams cams cams megabob 60 80,274 12-31-2013 01:19 AM
Last Post: gze spec
