Valve Springs upgrade question..
07-01-2010, 08:45 PM
hey Robokill... thanks...
THese springs are having higher tension so i'm worried if i'll get the desired effect.. hoping to do a Oil Cooler setup as well... Cheated on my いたずらな女の子 and now I can't get enough of her.. |
07-01-2010, 09:01 PM
oil cooler and FMIC are not rocketscience - you'll be fine accomplishing that... just a few rulez to follow as robokill stated and make sure everything is sealing properly and away you go... some simple airducts to chanel the incoming air to the coolers are also a very good idea (you can do them out of simple sheetmetal or even plastic as long as they are properly fixed to the car)
AE86 ex-daily |
07-01-2010, 09:05 PM
Thanks bean bandit.. I will definitely look into this...
I think cooling will be a problem as my country is very warm..... so cooling will definitely need help.. Cheated on my いたずらな女の子 and now I can't get enough of her.. |
07-01-2010, 09:10 PM
we usualy duct with thin allysheet and make a closed channel to the cooler - for safety reason finish the last inch with some ruber or similar to avoid the sheet cutting into something through vibration and have a little margin if you would ever bump into somthing...
something like that... http://www.dsmtuners.com/forums/attachme...p_6730.jpg AE86 ex-daily |
07-01-2010, 09:17 PM
that looks nice..
that's basically extending the ends of the Intercooler to the bumper right??? the rubber is towards the bumper or towards the cooler or both??? Cheated on my いたずらな女の子 and now I can't get enough of her.. |
07-01-2010, 09:29 PM
Rubber on every sharp edge I would suspect. The example bean gave you doesnt look like it will seal off or guide as much as possible, but it will prevent air from going around the IC, so it's very likely going to help.
07-01-2010, 09:49 PM
sounds good bro...
same concept goes for the oil cooler i guess.. Cheated on my いたずらな女の子 and now I can't get enough of her.. |
07-03-2010, 01:46 PM
heshan Wrote:based on my mechanic once i add the new springs the engine will Revv much faster than stock after 5k... total nonsense, can I suggest you find a new mechanic? |
07-06-2010, 06:33 AM
Sam-Q Wrote:heshan Wrote:based on my mechanic once i add the new springs the engine will Revv much faster than stock after 5k... Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
| 4A-GE valve shim disintegrated | DaLanZhu | 2 | 2,374 |
04-30-2025 12:54 PM Last Post: DaLanZhu |
| 4AGE Valve Buckets Scored | Steller Engineering | 2 | 2,472 |
| 20 Valve Blacktop smoking after engine flush - why? | RolanTHUNDER | 2 | 3,625 |
| HKS valve springs | totta Crolla | 3 | 4,157 |
| Radiator oem or upgrade on racecar? | Jimmi The Kid | 5 | 7,859 |
06-23-2017 05:21 PM Last Post: pack |
