Vacuum plenum tank
10-06-2008, 11:18 PM
Vacuum plenum tank
Hi guys
Could you help me find a vacuum plenum for my ITB 16v conversion? I know arpadal has bought one - but I cannot find one? Huge plus if located in EU! - Thanks, Niels |
10-07-2008, 12:12 PM
| Vacuum plenum tank | |||
10-24-2008, 05:58 PM
Vacuum plenum tank
Make one yourself - very easy to do.
Get an old 16v fuel rail - get a tap and run a thread into the 4 injector holes on the fuel rail. Got to a hardware store and get 4 threaded hose barb fittings. The remaining holes can be tapped for other things like the map sensor outlet, brake booster, FPR vaccum feed etc. All very very easy to do, job done and looks neat as well. If you dont have the 16v injectors as you are running 20v ITB's it also means that you can mount this where the stock fuel rail sits. Cheers James ![]() http://www.eight-six.co.uk - read the blog! UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk |
10-28-2008, 02:36 AM
Vacuum plenum tank
I have one if you want it, I got it from Golden eagle in the states and bought all the fittings aswell, I fitted a silvertop so don'y have any need for it .
Cheers Ivan 1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1 |
| bubbles in expansion tank? | fax0815 | 5 | 8,417 |
04-28-2017 04:57 PM Last Post: fax0815 |
| US-spec vacuum hard lines | LordTD | 2 | 6,814 |
04-27-2015 07:18 PM Last Post: Project D |
| Cylinderhead ventilation - greasy plenum... | Lt86 | 9 | 15,878 |
04-02-2015 10:41 PM Last Post: Lt86 |
| Fuel Tank Modification | apardal | 1 | 7,066 |
08-11-2014 06:59 PM Last Post: Ivan141 |
| Pressure gathering in fuel tank | Apolan | 9 | 19,105 |
05-18-2014 06:18 AM Last Post: chenfon |
![AEU86 AE86 - Vacuum plenum tank [Image: AEU86 AE86 - Vacuum plenum tank]](http://i57.photobucket.com/albums/g239/N2AE86/memberbanner1jpg.jpg)
