Trueno - Headlight Rods
04-26-2012, 09:33 PM
Just replace the stock rod with two threadend rods at the end and an adjusting nut in between, so you can exactly turn it to the lenght you need.... Thought about that? Wave
AE86 Full Hybrid - Burns rubber and gasoline
04-27-2012, 12:01 AM
YEs that's what i'm going to do on mines... But the measurement is to get the ideal length on mines only!
Thumbs up!
04-27-2012, 01:34 AM
165mm center circle to center circle
04-27-2012, 10:42 AM
Thanks! Thumbs up!
04-27-2012, 10:45 AM
You are welcome Brother
04-27-2012, 11:23 AM
With that i can now make mines that same size and if they still wont open, the problem is on the small metal piece that makes the rod move!
Regards!
  Alternative source for headlight motors TheRekiker 5 1,157 08-18-2026 02:32 PM
Last Post: decryphe
  STL file for the early spec Levin headlight ball joint plastic clip DaLanZhu 2 2,772 04-26-2025 03:24 PM
Last Post: DaLanZhu
  AE86 Headlight + wiper wiring (levin) bozu 11 23,163 09-19-2017 02:06 PM
  Trueno headlight help kazi 9 18,195 04-20-2017 09:37 AM
Last Post: kazi
  TRUENO - LHD headlight solutions pack 11 19,635 09-21-2016 10:29 AM
Last Post: pack
