Trueno Coupe South Africa
06-07-2018, 07:47 PM
(This post was last modified: 06-07-2018 07:52 PM by banpei.)
Post: #151
The F20 box is basically the gearbox fitted to the Honda S2000. The engine of the S2000 is called a F20C, hence the name. The gearbox is the same as the ones used in the RX-8 and the IS200/Altezza: the Aisin AZ6. I'm not sure if they are 100% the same as they might have different brackets and such.
Leen produced a conversion kit for these gearboxes to bolt it on the 4AGE. See also these threads: http://www.aeu86.org/forum/Thread-Assemb...-LEEN-J160 http://www.aeu86.org/forum/Thread-LEEN-G...-quot-A-qu However after the initial 5 produced, Joe stopped making them. Also http://www.gearboxconversion.com/ seems to be parked at Sedo. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
06-07-2018, 09:40 PM
(This post was last modified: 06-07-2018 10:01 PM by MIGGZFSU.)
Post: #152
Aaaahhh awesome thanks for the info
Sent from my F3111 using Tapatalk Did somemore work on the Shinigami Test fitted the throttles to make sure all fits Fitting the pulleys, done the 20v power steering pump and custom made line, fitted the bosch 440 pump, will be temp till I make the surge tank I want. Test fitting the denso Toyota yaris coils which I had to sand down Grinding the pully to fit the 60-2 gear ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my F3111 using Tapatalk |
| Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 18,569 |
| Track AE86 Build from south america | Nurburgring | 3 | 9,355 |
| My Drift project - 83' Trueno coupe | doggy | 158 | 299,718 |
10-23-2012 10:58 AM Last Post: Lightning |
| AE86 Trueno Coupe (SR5-GTS)//Sweden | Allexz | 71 | 88,478 |
03-16-2009 10:02 PM Last Post: banpei |
![AEU86 AE86 - Trueno Coupe South Africa [Image: AEU86 AE86 - Trueno Coupe South Africa]](https://www.aeu86.org/sticker-banner-468.gif)
![AEU86 AE86 - Trueno Coupe South Africa [Image: AEU86 AE86 - Trueno Coupe South Africa]](https://uploads.tapatalk-cdn.com/20180607/c2cea69353e52193c1e53e555eba44bb.jpg)
![AEU86 AE86 - Trueno Coupe South Africa [Image: AEU86 AE86 - Trueno Coupe South Africa]](https://uploads.tapatalk-cdn.com/20180607/29da4d9c035323462fdc8bcfc692bc0e.jpg)
![AEU86 AE86 - Trueno Coupe South Africa [Image: AEU86 AE86 - Trueno Coupe South Africa]](https://uploads.tapatalk-cdn.com/20180607/10db75bfb052a7034269da18f8e4302a.jpg)
![AEU86 AE86 - Trueno Coupe South Africa [Image: AEU86 AE86 - Trueno Coupe South Africa]](https://uploads.tapatalk-cdn.com/20180607/c5424fa3641390937e786ace50367a97.jpg)
![AEU86 AE86 - Trueno Coupe South Africa [Image: AEU86 AE86 - Trueno Coupe South Africa]](https://uploads.tapatalk-cdn.com/20180607/267c695d9c7b1146d42749f74f2324c7.jpg)
![AEU86 AE86 - Trueno Coupe South Africa [Image: AEU86 AE86 - Trueno Coupe South Africa]](https://uploads.tapatalk-cdn.com/20180607/ad35db3e44b3118beca6b0fed70f560b.jpg)
![AEU86 AE86 - Trueno Coupe South Africa [Image: AEU86 AE86 - Trueno Coupe South Africa]](https://uploads.tapatalk-cdn.com/20180607/7b0d68b119dde0877dfc888e0d4fb70d.jpg)
![AEU86 AE86 - Trueno Coupe South Africa [Image: AEU86 AE86 - Trueno Coupe South Africa]](https://uploads.tapatalk-cdn.com/20180607/2e824c1dbdecdca0002869dd9c8440d1.jpg)
