Toyota COPs tach signal
01-13-2014, 09:14 PM
The 1ZZFE coils I am using have a tach output but what kind of signal do they put out? I tried using a oscilloscope connected to ground but I got no signal. I did not try with the scope connected to 12 V or by using a pull up resistor and this will be next if I can't find a certain answer.
[Image: AEU86 AE86 - Toyota COPs tach signal]
01-14-2014, 10:07 AM
It's not a tach output but a feedback (confirmation) signal.
Far as I know, it's a 5V square wave signal, like in most Toyota.
01-14-2014, 10:39 AM
You are right it is a feed back to the ECU but I would like to use it as a tach signal Smile But I don't get at 5 V signal.
01-14-2014, 10:51 AM
I knew we where talking about that few years ago.
Look here:
http://www.aeu86.org/viewtopic/ae86/t/10...c/start=25
01-14-2014, 02:49 PM
Nice! Did you ever get the S2k dash working?
  VSS signal from stock cluster ? Uzelac 7 11,387 12-13-2011 01:42 PM
Last Post: Uzelac
  left turn signal always flashes. bulbs are good Mitchen 1 3,722 07-27-2010 12:33 AM
Last Post: Mitchen
  Tacho Signal Levin Coupe with pics Okami 10 16,521 05-31-2010 08:56 PM
  tacho signal wire totta Crolla 7 15,311 04-12-2010 09:44 PM
Last Post: Okami
  EU zenki turn signal problem/question Spitfire 1 4,050 05-04-2007 12:24 PM
Last Post: Spitfire
