Torque
01-04-2005, 09:13 PM
Torque
Can you get 180+NM from a 4ag engine? Or what is the max without going FI?
And what mods would you need? |
01-04-2005, 11:04 PM
Torque
I doubt it...that's 2 liter territory.
An english fellow on club4ag is claiming such numbers, but I havent seen the dyno sheet so I dont really believe it. FABRICA MI DIEM, PVNC! |
01-05-2005, 12:59 AM
Torque
180 nm from a 4age turbo it :-) without FI hmmz
standard should be around 130-140nm so you should be able to get it up to 160 max i think if you bore it to 82mm 3xx cams etc will be one hell of an engine but way to expensive better take 4agze then Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
01-05-2005, 12:54 PM
Torque
You can get 190Nm - take a look at 4AGE engines for rallying.
I think - the major factor here was higher CR - ~11 and more. |
01-05-2005, 02:04 PM
Torque
Can you get that amount of torque in the lower rev range or only from 5k and up? Because most race engines have no torque down low.
01-05-2005, 02:06 PM
Torque
Now way to get low RPM torque with NA race engine :-(
| Torque settings | kazi | 4 | 11,415 |
03-28-2017 12:15 AM Last Post: kazi |
| torque setting head cylinder bolts | izanagi | 1 | 7,012 |
05-29-2015 01:23 AM Last Post: oldeskewltoy |
| Need help finding an axle that can handle high hp/torque | kevcov | 5 | 9,488 |
04-17-2011 10:50 AM Last Post: Prime86 |
| 4AGE Silvertop torque setting | christsang7 | 3 | 20,258 |
07-31-2009 06:12 AM Last Post: christsang7 |
| T50 G/box tightening torque question. | misterforager | 2 | 8,329 |
04-20-2009 01:41 AM Last Post: apardal |
