Tomei 16V poncams + Tomei technical trax 1.5 way LSD
09-16-2016, 06:30 PM (This post was last modified: 09-16-2016 06:31 PM by oldeskewltoy.)
both Bean and totta are correct.... and both add useful information....
BUT.... for the mild builder*... try to keep the variables to a minimum. Scavenging can add a little bit to a well tuned engine, but not paying attention to the basics can cost you a lot more.... the same can be said for intake design/length, there is a lot that can be achieved without changing the intake design, and a lot can be lost if the change isn't performed correctly.
* - mild builder: retains the stock engine management, and stock intake system.
It is up to you as to how "deep" you get involved. The skill level required tends to go up with the hp.
As to your question about centerlines, the cam sheet is the recommended settings by the cam manufacturer, I tell everyone follow these recommended settings, and **IF** you have the time (and the $$), try changing the adjustments while on a dyno and see the results.... but if your cams are set to the specs, it should run, and run well as long as the internal engine variables(cam duration-compression) are well matched.
Dan -
09-16-2016, 07:52 PM
now where did I put that winning lottery ticket to buy my own dyno and perform all the research Big Grin
AE86 ex-daily
09-16-2016, 09:56 PM
the tvis appeared to restrict air flow lower down so jamming it open actually makes the running of the engine much better and low down has improved marginally. but anything is better than what it was before.
I'm going to stick with the cat cams in my new build to see if they are better with the higher comp
  Kaaz 1.5 way Diff - Driveshaft Compatability chrisae86 1 3,409 05-10-2021 01:02 PM
Last Post: Project D
  Help needed: is it 1 way or 1.5way LSD Dino86 2 4,758 05-17-2019 09:08 AM
  corolla idles way to high HELP PLEASE 86_ae86_coupe 9 11,488 12-01-2011 10:05 AM
Last Post: Uzelac
  Headlights the irish way dikolotour 12 19,301 09-02-2011 01:29 AM
Last Post: ae86_ladd
  clutches and spring washers position in 2 Way TRD diff???? T_AE86 3 6,245 09-01-2011 10:50 AM
Last Post: T_AE86
