The Truenos Transformation
02-03-2007, 06:44 PM
Much better and it looks quite comfy in there.
tis not a show car
buiulding her to drift with i plan on taking the engine out nex year maybe so when that is out i will paint the bay black the wiring in the engine bay has already been sorted out not looking to build a minter but a car that i can learn to drift in and hopefully become competative with, but as the car is also my daily driver i wanted soething i nthe back to make it look a bit betetr and bring the noise level down as for the wiring i nthe car itself, thts geting sorte before i put the dash back in place ![]() DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS |
02-06-2007, 02:14 AM
anyway here is list of what has been done over the past couple of months
well a small update on the car after almost 4 months my new diff arrives home tomorrow al kitted and built up and ready to be fitted to the car interior is getting all sorted in my next 2 days off, IE putting the seats and dash back in. fitted since car went off the road full prothane bushing kit water and oil temp, oil pressure and volt guages fixed my dash fixed dash lights light weight alternator pulley twin electric fans, along with a thermostatic controll switch in place of viscous 4 point harness'es sorted all cabling out greddy radiator pipe TRD 2Way LSD Helix cerametalic Paddle clutch and larger 212mm flywheel new Crown and Pinion still waiting to be fitted TRD Engine mounts CUSCO gearbox mount Blitz brake pads plans for end of year full suspension overhall ![]() DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS |
02-06-2007, 10:17 PM
got guages fitted
nice and bright lol oil pressure oil temp water temp and volt ![]()
02-06-2007, 10:38 PM
wow, great car you are setting up there. keep up the good work and keep us posted of the progress.
i like those gauges you just installed. Pedro Velado GT-S Owner
02-09-2007, 10:23 PM
car looks good
i'm really liking the fender flares ![]() "Strictly All Things 86" |
02-11-2007, 12:31 PM
Nice
![]() AE86 Project |
02-23-2007, 10:35 PM
well the diff is now fitted back upto the car
still got the halfshafts to go on and galf the driveshaft as well i cant find the back brake pads i took off of the car which is a bit worrying as they were in perfect condition lol, might need to go buy more now front brakes have seized, bollocks pitworks pads on there just now have blitz ones to go on other problem i have encountered is a problem with the alternator, it is only charing between 9-11 volts which is not enough, however when i got it tested it tested as perfect weird, also managed to set the alternator cable on fire twice, hmm this car has me paranoid now ![]() DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS |
03-11-2007, 08:58 PM
ok then
caliper rebuild kit ordered for the rear brakes alternator now charging properly, was one fucking cable going from the fusebox to the alternator that had a split in it, fukcing raging, knew it would be somehting simple, just spending the time finding it alloys have been painted same colour as the car, done at home = mega cheapness, they look quite good as well dash is all back in, just ned to put the seats and harnesses in battery has been relocated to the boot, from back of the passenger seat gearbox mount is done engine mounts are being done soon, although they look like a right pain in the arse to do any advice? still to fit blitz brake pads to the front sorry no pics but battery in camera is dead and my mobile had an accident with the washing machine ![]() DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS |
03-18-2007, 12:05 AM
well now
the alternator problem has been sorted, was one shitty cable going to the fusebox grrrr TRD engine mounts are fitted starter motor is now working properly all the seats are in as are the 2 harnesses electric fan switch and fog light switch now have proper mounts battery has been relocated to the boot rear calipers are being rebuilt over next couple of days steering wheel is in alloys are now midnught purple ![]() ![]() ![]() ![]() ![]() also had a bit of a problem with the engine the oil cooler burst its pipe and pissed oil everywhere when i was not there what happened was i had the car running for about 10 minutes, went out switched the car off and went to the cinema in my other car, came back from the cinema and seen something wet under the car in the headlights and knew what it was straight away on investigating the followig day the cooler pipe was burst, i have been lucky it must have burst just before i turned the engine off as the engine is 100% fine thats the updates for now ![]() DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS |
| OST-069: Transformation | oldeskewltoy | 19 | 19,524 |
01-14-2021 04:41 PM Last Post: mad.matt |
![AEU86 AE86 - The Truenos Transformation [Image: AEU86 AE86 - The Truenos Transformation]](https://www.aeu86.org/sticker-banner-468.gif)
![AEU86 AE86 - The Truenos Transformation [Image: AEU86 AE86 - The Truenos Transformation]](http://i13.photobucket.com/albums/a287/yaffa99/ae86/ae86bigyin.jpg)
![AEU86 AE86 - The Truenos Transformation [Image: AEU86 AE86 - The Truenos Transformation]](http://i13.photobucket.com/albums/a287/yaffa99/ae86/DSC08969.jpg)
![AEU86 AE86 - The Truenos Transformation [Image: AEU86 AE86 - The Truenos Transformation]](http://i1129.photobucket.com/albums/m507/doctorokka/86%20Garage%20Magazine/86GMagLogo-small.png)
![AEU86 AE86 - The Truenos Transformation [Image: AEU86 AE86 - The Truenos Transformation]](http://www.etwanix.dk/AE86Banner4.jpg)
![AEU86 AE86 - The Truenos Transformation [Image: AEU86 AE86 - The Truenos Transformation]](http://i13.photobucket.com/albums/a287/yaffa99/ae86/next/DSCF4024.jpg)
![AEU86 AE86 - The Truenos Transformation [Image: AEU86 AE86 - The Truenos Transformation]](http://i13.photobucket.com/albums/a287/yaffa99/ae86/next/DSCF4025.jpg)
![AEU86 AE86 - The Truenos Transformation [Image: AEU86 AE86 - The Truenos Transformation]](http://i13.photobucket.com/albums/a287/yaffa99/ae86/next/DSCF4026.jpg)
![AEU86 AE86 - The Truenos Transformation [Image: AEU86 AE86 - The Truenos Transformation]](http://i13.photobucket.com/albums/a287/yaffa99/ae86/next/DSCF4027.jpg)
![AEU86 AE86 - The Truenos Transformation [Image: AEU86 AE86 - The Truenos Transformation]](http://i13.photobucket.com/albums/a287/yaffa99/ae86/next/DSCF4028.jpg)
