The Truenos Transformation
06-22-2007, 05:58 PM
Post: #81
Yo Ivan it was Ebay
![]() here is the link http://search.stores.ebay.com/CNSAutoPar...33QQsofpZ0 link to the shop all it is showing is the age stuff as i done a search for it individual items pistons and rings http://cgi.ebay.com/ebaymotors/85-87-TOY...QQtcZphoto ACL bearings http://cgi.ebay.com/ebaymotors/88-91-TOY...QQtcZphoto very good pricew
![]() DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS |
06-22-2007, 06:59 PM
Post: #82
Thanks...very nice prices indeed..This is the first time I can clearly see that the US pistons have a lower compression ratio. My old pistons here have a very small dome to them, these ones have a slight dish. Though at that price (less than 1 new toyota piston) I would be inclined to make up for the loss in compression with a headgasket.
06-26-2007, 06:42 PM
Post: #83
tidied the block up a little bit
along with the sump and engine mounts need to decided what colour to paint the engine bay white or black white to spot leaks etc black to make it blend in with the paint a bit more i hate the contrast of the red against the paint, prob hate the white even more ![]() ![]() ![]() ![]() conrods are off getting lightened and balanced with the crank and fly now also ordered all the parts for my new filter set up ![]() DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS |
06-26-2007, 07:18 PM
Post: #84
Nice color!
But why not make the enginebay dark grey? Then you can still spot oil leaks and it blends in with the color of the car. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
06-26-2007, 07:27 PM
Post: #85
banpei Wrote:Nice color! had not actually thought about that, cheers dude
06-28-2007, 10:14 PM
Post: #86
updated spec list
should stay like this for a while, while i save more money up haha Engine 7 Rib Big Port Engine Apexi AFC ISKY Racing Cams Adj Fuel regulator Uprated fuel pump 4-1 manifold Straight through underaxle exhaust A'PEXi power intake SARD Magnetic Oil plug Grex Oil Cooler greddy radiator pipe TRD Engine mounts AirCon removed Viscous fan removed and twin electric fitted TRD Rad Cap Lightened and Balanced Crank Lightened and Balanced Conrods Full Fresh Rebuild AE101 Oil Pump for beter flow TRD 0.8mm Metal Headgasket P.A.S.S Racing Underdrive Light Weight Racing Pulleys ACL RACE SERIES Crankshaft Main Bearings ACL RACE SERIES Connecting Rod Bearings Transmission TRD Quick shift Helix Cerametalic Paddle Clutch TRD 2 way Limited Slip Differential Cusco Gearbox mount Lightened and Balanced Flywheel ARP flywheel bolts Suspenion Front CoilOvers Cusco Topmount Camber Adjustment Rear TRD adjustable shocks and Springs 'Achieve Sports' Full Roll Cage Alloy RCA's Adjustable Rear Lateral Rod Front Strut Brace Full Poly Bush Kit (just fitted) Brakes Uprated Brake Rotors and Blitz Pads new rear discs Cusco Brake Enhance Exterior Extreme Dimensions Body Kit TRD Spoiler 14” Celica Supra Alloys, Painted Same as car Front 14x7 rear 14x7 Interior Standard Seats from a later spec 1986 car MOMO 4 point harnesses MOMO Wheel and extended hub Fully stripped Oil Pressure Guage Oil Temperature Gauge Volt Gauge Water Temp Gauge All AutoGauge Smoke series Steering Battle Version Steering spacer Kit2 ![]() DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS |
06-29-2007, 10:30 AM
Post: #87
Yin, you drive much impressive mods list
06-29-2007, 03:09 PM
Post: #88
Wow! That is a long and very nice speclist!
06-30-2007, 01:09 PM
Post: #89
Cheers guys
06-30-2007, 03:36 PM
Post: #90
my gaskets, oil pump, and racing pulleys are in the country, i know this because i just got another fucking letter from parcel force asking me for more fucking money, the vat was fine £13.55, its the parcel force fucking handling fee i hate £13.50 wankers
| OST-069: Transformation | oldeskewltoy | 19 | 19,403 |
01-14-2021 04:41 PM Last Post: mad.matt |
![AEU86 AE86 - The Truenos Transformation [Image: AEU86 AE86 - The Truenos Transformation]](http://i13.photobucket.com/albums/a287/yaffa99/ae86/ae86bigyin.jpg)
![AEU86 AE86 - The Truenos Transformation [Image: AEU86 AE86 - The Truenos Transformation]](http://i13.photobucket.com/albums/a287/yaffa99/ae86/engine/DSC00027.jpg)
![AEU86 AE86 - The Truenos Transformation [Image: AEU86 AE86 - The Truenos Transformation]](http://i13.photobucket.com/albums/a287/yaffa99/ae86/engine/DSC00028.jpg)
![AEU86 AE86 - The Truenos Transformation [Image: AEU86 AE86 - The Truenos Transformation]](http://i13.photobucket.com/albums/a287/yaffa99/ae86/engine/DSC00029.jpg)
![AEU86 AE86 - The Truenos Transformation [Image: AEU86 AE86 - The Truenos Transformation]](http://i13.photobucket.com/albums/a287/yaffa99/ae86/engine/DSC00030.jpg)
![AEU86 AE86 - The Truenos Transformation [Image: AEU86 AE86 - The Truenos Transformation]](https://www.aeu86.org/sticker-banner-468.gif)
