The Truenos Transformation
06-22-2007, 05:58 PM
Post: #81
Yo Ivan it was Ebay Wink
here is the link
http://search.stores.ebay.com/CNSAutoPar...33QQsofpZ0
link to the shop all it is showing is the age stuff as i done a search for it
individual items
pistons and rings
http://cgi.ebay.com/ebaymotors/85-87-TOY...QQtcZphoto
ACL bearings
http://cgi.ebay.com/ebaymotors/88-91-TOY...QQtcZphoto
very good pricew Smile
[Image: AEU86 AE86 - The Truenos Transformation]
DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS
06-22-2007, 06:59 PM
Post: #82
Thanks...very nice prices indeed..This is the first time I can clearly see that the US pistons have a lower compression ratio. My old pistons here have a very small dome to them, these ones have a slight dish. Though at that price (less than 1 new toyota piston) I would be inclined to make up for the loss in compression with a headgasket.
06-26-2007, 06:42 PM
Post: #83
tidied the block up a little bit
along with the sump and engine mounts
need to decided what colour to paint the engine bay
white or black
white to spot leaks etc
black to make it blend in with the paint a bit more
i hate the contrast of the red against the paint, prob hate the white even more Confused
conrods are off getting lightened and balanced with the crank and fly now
also ordered all the parts for my new filter set up
06-26-2007, 07:18 PM
Post: #84
Nice color! Thumbs up!
But why not make the enginebay dark grey? Then you can still spot oil leaks and it blends in with the color of the car.
06-26-2007, 07:27 PM
Post: #85
banpei Wrote:Nice color! Thumbs up!
had not actually thought about that, cheers dude Wink
06-28-2007, 10:14 PM
Post: #86
updated spec list
should stay like this for a while, while i save more money up haha
Engine
7 Rib Big Port Engine
Apexi AFC
ISKY Racing Cams
Adj Fuel regulator
Uprated fuel pump
4-1 manifold
Straight through underaxle exhaust
A'PEXi power intake
SARD Magnetic Oil plug
Grex Oil Cooler
greddy radiator pipe
TRD Engine mounts
AirCon removed
Viscous fan removed and twin electric fitted
TRD Rad Cap
Lightened and Balanced Crank
Lightened and Balanced Conrods
Full Fresh Rebuild
AE101 Oil Pump for beter flow
TRD 0.8mm Metal Headgasket
P.A.S.S Racing Underdrive Light Weight Racing Pulleys
ACL RACE SERIES Crankshaft Main Bearings
ACL RACE SERIES Connecting Rod Bearings
Transmission
TRD Quick shift
Helix Cerametalic Paddle Clutch
TRD 2 way Limited Slip Differential
Cusco Gearbox mount
Lightened and Balanced Flywheel
ARP flywheel bolts
Suspenion
Front CoilOvers
Cusco Topmount Camber Adjustment
Rear TRD adjustable shocks and Springs
'Achieve Sports' Full Roll Cage
Alloy RCA's
Adjustable Rear Lateral Rod
Front Strut Brace
Full Poly Bush Kit (just fitted)
Brakes
Uprated Brake Rotors and Blitz Pads
new rear discs
Cusco Brake Enhance
Exterior
Extreme Dimensions Body Kit
TRD Spoiler
14” Celica Supra Alloys, Painted Same as car
Front 14x7
rear 14x7
Interior
Standard Seats from a later spec 1986 car
MOMO 4 point harnesses
MOMO Wheel and extended hub
Fully stripped
Oil Pressure Guage
Oil Temperature Gauge
Volt Gauge
Water Temp Gauge
All AutoGauge Smoke series
Steering
Battle Version Steering spacer Kit2
06-29-2007, 10:30 AM
Post: #87
Yin, you drive much impressive mods list Evil
06-29-2007, 03:09 PM
Post: #88
Wow! That is a long and very nice speclist! Thumbs up!
06-30-2007, 01:09 PM
Post: #89
Cheers guys Smile
06-30-2007, 03:36 PM
Post: #90
my gaskets, oil pump, and racing pulleys are in the country, i know this because i just got another fucking letter from parcel force asking me for more fucking money, the vat was fine £13.55, its the parcel force fucking handling fee i hate £13.50 wankers
  OST-069: Transformation oldeskewltoy 19 19,420 01-14-2021 04:41 PM
