The Truenos Transformation
06-19-2007, 10:27 PM
Post: #71
well i think something is missing from the picture below
anyone guess what it is
[Image: AEU86 AE86 - The Truenos Transformation]
and here is some of what is missing here this is the fubared one
clutch and flywheel removed as that is what i need off of that block
everything else is being replaced with new
212mm flywheel and a helix paddle clutch
so waiting on gasket set an AE101 oil pump to arrive ands then thats everything
Also think i have settled on what route i am going to go with my engine
going to stick with the 16v 4A-GE, but aiming for 200bhp
This will be acheived using mainly TODA components but with a few other manufacturers as well
the P.A.S.S racing lightweight underdrive pulley kit
http://store.autosportsupplies.com/merch...ry_Code=EP
illegal garage one peice lightweight prop
http://forums.club4ag.com/zerothread?id=5600
Lightweight Flywheel, possably toda but not sure yet
lighten and balance crank, flywheel
and the
AE86 high cam computer KIT.
(STAGE-III Type 200PS)
Price: $4500
Kit contents
(1)TODA forged piston set (ø81.00mm / ø81.25mm / ø82.00mm)
(2)High power camshaft IN 280 (10.3) x1 EX 288 (10.5) x1
(3)Adjustable cam pulleys x2
(4)Inner-shim KIT
(5)TODA Fuel computer.(Standard computer trade-in)
(6)Fuel MAP switch ( fuel control) with fuel regulator
(7)Sports injection KIT
Up rated valve springs set
Option : Ignition timing MAP switch (for Ignition timing control)
the TODA kit comes to about £2260
everything else is about £1500 including mapping
which should see in excess of 200bhp
DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS
06-19-2007, 11:02 PM
Post: #72
You are going for the extreme in 4age power production there.. you sure that's what you want? I can hardly imagine 200hp 1.6l engines that will last very long without some serious improvements to the engine. Does the TODA kit come with better rods too? Cause those are by far the weakest point in a high-revving engine. Might be something to consider if you're spending all that money on the rest of the engine.
06-19-2007, 11:17 PM
Post: #73
opps the kit doesnt come with rods
also meant to add forged rods as well Big Grin not sure what kind yet
i have another car anyway Ivan that i can use, just out an out building this carfor myself, i plan on keeping the car a long time so it will just got from stage to stage i reckon, it is a longterm project for me and my dad Smile
06-20-2007, 10:44 PM
Post: #74
someting missing from the trailer
hmmm
oh wait here it is
started stripping the engine down today
removed ancileries before we put it onto the stand
accordig the cambelt covers it was last done at 91k miles
so i think it has done 164k and not the 64k he thought lol
got the camcovers off and what an intersting state the head is in oil is bloody solid, think i might use the old head as it seems to be in betetr condition, will decided once the head is completely cleaned up
cams seems a little rusty as well
some random MR2 engine parts that will soon make there way to ebay
asa brucey bonus i now have a spare 212mm flywheel didnt know the Mr2's came with them
06-21-2007, 10:51 AM
Post: #75
Hi!
What pistons are those? Are they forged?
Best regards
06-21-2007, 01:12 PM
Post: #76
apardal Wrote:Hi!
Best regards
Quote:NRP Nippon
Cast.
06-21-2007, 07:17 PM
Post: #77
nice
06-21-2007, 07:22 PM
Post: #78
jamiemirror Wrote:
apardal Wrote:Hi!
Best regards
Quote:NRP Nippon
Cast.
LOL cheers Jamie Smile
06-21-2007, 10:25 PM
Post: #79
glad i got the engine cheap as all i am using is the block
not happy with the rest
cylinder head bolts are blue from heat, think it has been given a roasting at some point,
not happy with the crank, there is a mark on it that has left a score in the coresponding bearing shell.
so pretty much all i am taking from this is the block, and nothing else
ok so here we are so far
ACl Race bearings + Pistons/piston rings delivered from america £121
engine £68
Toyota Genuine Gasket set
AE101 20v oil pump
PASS Racing underdrive pulley kit all £350 delivered from america
Water Pump £35
spark plugs £20
Timing belt £20
TRD 0.8mm Metal headgasket £50
plus getting the flywheel and crank lightened and balanced tomorrow charging £50 plus vat, done some name dropping for that price Wink
06-22-2007, 05:23 PM
Post: #80
Could you hook me up with the address for those pistons and bearings at that price?
  OST-069: Transformation oldeskewltoy 19 19,446 01-14-2021 04:41 PM
