The Truenos Transformation
06-07-2007, 08:08 PM
Post: #61
I cant wait for your car to get back on the road, maybe then you'll stop finding links for me to spend money!
06-07-2007, 08:21 PM
Post: #62
haha
nah never i will still be sending you links Big Grin
cause i wil lstill be looking for parts to upgrade always
just ordered the pistons
ACL race bearings
ARP heavy dury clutch bolts
and my cars maskot
in the mil today i got
SARD magnetic oil plug
APexi filter
and TRD horn button
[Image: AEU86 AE86 - The Truenos Transformation]
DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS
06-07-2007, 10:07 PM
Post: #63
ok some new parts arrived today
A'PEXi power intake
SARD Magnetic Oil plug
TRD horn button
also my TRD 0.8 Metal Headgasket arrived
raises the compression some
got a new set of drift rims as well
ordered the ACL Bearings, and new pistons and rings from america £121 delivered
also ordered the ARP Flywheel bolts
Dad has gotten me an engine from ebay
£68
perfect for full rebuild
going to see how much to get the crank lightened and balanced as well
the workshop
lol Big Grin
cam covers have been painted same colour as the car
they look black in the pic however lol
06-14-2007, 12:07 AM
Post: #64
ARP flywheel bolts turned up
just trying to source an oil pump from a AE101 levin now, thats the 20v silvertop 4age has higher presure and flows more, only prob is enever done this car in the UK
also trying to get hold of some TODA valve springs whilst i have the engine stripped down this far
gettinf the flywheel and crank lightened and blanced as well
£50 plus vat
trying to source a ARP bolt kit for the engine as well for a reasonable price
most of my parts are coming from america
06-16-2007, 10:24 PM
Post: #65
well collected my engine from preston
199.9 miles down and the same back
left at 3:30 pm got there at about 7:15 pm left an hour later and got home at 12:45am my 1.6 mk2 jetta wasnt to keen on the hills on the way back haha with trailer and engine on tow
64k 7rib engine assuming it is a redtop as it has red cam lettering
seems in pretty good nick, has new dizzy cap, rotor arm, leads, and plugs, t-vis also looks new but thats not much use to me.
still waiting on parts to arrive befre the rebuild can start
anyone know of the MR2 or AE86 crank is better?
anyway here are some pics
06-16-2007, 10:53 PM
Post: #66
not to disappoint you but thats a 7 ribbed blue top engine. Which means
40mm crankshaft
18mm piston pin
Its not the 7 ribbed engine which had a smallport head and the same crankshaft and connecting rods as a 20v or gze.
These engines are fine. Seen one at 200 hp with a 3 ribbed lower block.
actually I would put this engine and drop it straight in. Then rebuild the original engine.... As long as you aint spending alot of money on the engine and it won't reach more than 180 or more HP its no use having a 7 ribbed.
06-16-2007, 11:10 PM
Post: #67
i know its not a smallport engine
my original engine is a 3rib big port
not rebuilding my original as it needs a rebore and oversized pistons
i plan on buying the toda highcam computer kit in a couple of years so i will use the new engine as a base as it is low milage
AE86 high cam computer KIT.
(STAGE-III Type 200PS)
Price: $4500
Kit contents
(1)TODA forged piston set (ø81.00mm / ø81.25mm / ø82.00mm)
(2)High power camshaft IN 280 (10.3) x1 EX 288 (10.5) x1
(3)Adjustable cam pulleys x2
(4)Inner-shim KIT
(5)TODA Fuel computer.(Standard computer trade-in)
(6)Fuel MAP switch ( fuel control) with fuel regulator
(7)Sports injection KIT
Option : Ignition timing MAP switch (for Ignition timing control)
06-18-2007, 12:10 PM
Post: #68
a box arrived for me today
after paying te £33.03 charge to parcel force
robbing fucks
my ACL race bearings and pistons and piston rings
06-18-2007, 12:39 PM
Post: #69
Oh yeah, true racing series ACL (except trust washer but it doesn't matter). Do you like pistons quality ?
06-19-2007, 02:02 AM
Post: #70
piston quality seems finsd
they are NRP Nippon replacement parts
manufactured in Japan
the bearings have been recomended bu loads of folks Smile
  OST-069: Transformation oldeskewltoy 19 13,873 01-14-2021 04:41 PM
