The Truenos Transformation
02-03-2007, 06:44 PM
Much better and it looks quite comfy in there. Tongue
[Image: AEU86 AE86 - The Truenos Transformation]
tis not a show car
buiulding her to drift with
i plan on taking the engine out nex year maybe so when that is out i will paint the bay black
the wiring in the engine bay has already been sorted out
not looking to build a minter but a car that i can learn to drift in and hopefully become competative with,
but as the car is also my daily driver i wanted soething i nthe back to make it look a bit betetr and bring the noise level down
as for the wiring i nthe car itself, thts geting sorte before i put the dash back in place Big Grin
DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS
02-06-2007, 02:14 AM
anyway here is list of what has been done over the past couple of months
well a small update on the car
after almost 4 months my new diff arrives home tomorrow al kitted and built up and ready to be fitted to the car
interior is getting all sorted in my next 2 days off, IE putting the seats and dash back in.
fitted since car went off the road
full prothane bushing kit
water and oil temp, oil pressure and volt guages
fixed my dash
fixed dash lights
light weight alternator pulley
twin electric fans, along with a thermostatic controll switch in place of viscous
4 point harness'es
sorted all cabling out
greddy radiator pipe
TRD 2Way LSD
Helix cerametalic Paddle clutch and larger 212mm flywheel
new Crown and Pinion
still waiting to be fitted
TRD Engine mounts
CUSCO gearbox mount
Blitz brake pads
plans for end of year
full suspension overhall
02-06-2007, 10:17 PM
got guages fitted
nice and bright lol
oil pressure
oil temp
water temp
and volt
02-06-2007, 10:38 PM
wow, great car you are setting up there. keep up the good work and keep us posted of the progress.
Respect!
i like those gauges you just installed.
Pedro Velado
GT-S Owner
02-09-2007, 10:23 PM
car looks good
i'm really liking the fender flares Thumbs up!
"Strictly All Things 86"
02-11-2007, 12:31 PM
Nice Yummie!
AE86 Project
02-23-2007, 10:35 PM
well the diff is now fitted back upto the car
still got the halfshafts to go on
and galf the driveshaft as well
i cant find the back brake pads i took off of the car which is a bit worrying as they were in perfect condition lol, might need to go buy more now
front brakes have seized, bollocks
pitworks pads on there just now
have blitz ones to go on
other problem i have encountered is a problem with the alternator, it is only charing between 9-11 volts which is not enough, however when i got it tested it tested as perfect weird, also managed to set the alternator cable on fire twice, hmm this car has me paranoid now
03-11-2007, 08:58 PM
ok then
caliper rebuild kit ordered for the rear brakes
alternator now charging properly, was one fucking cable going from the fusebox to the alternator that had a split in it, fukcing raging, knew it would be somehting simple, just spending the time finding it
alloys have been painted same colour as the car, done at home = mega cheapness, they look quite good as well
dash is all back in, just ned to put the seats and harnesses in
battery has been relocated to the boot, from back of the passenger seat
gearbox mount is done
engine mounts are being done soon, although they look like a right pain in the arse to do any advice?
still to fit blitz brake pads to the front
sorry no pics but battery in camera is dead and my mobile had an accident with the washing machine
03-18-2007, 12:05 AM
well now
the alternator problem has been sorted, was one shitty cable going to the fusebox grrrr
TRD engine mounts are fitted
starter motor is now working properly
all the seats are in as are the 2 harnesses
electric fan switch and fog light switch now have proper mounts
rear calipers are being rebuilt over next couple of days
steering wheel is in
alloys are now midnught purple
also had a bit of a problem with the engine
the oil cooler burst its pipe and pissed oil everywhere when i was not there
what happened was i had the car running for about 10 minutes, went out switched the car off and went to the cinema in my other car, came back from the cinema and seen something wet under the car in the headlights and knew what it was straight away Sad it was darkwhen i left for the cinema so never see the oil
on investigating the followig day the cooler pipe was burst, i have been lucky it must have burst just before i turned the engine off as the engine is 100% fine thats the updates for now
  OST-069: Transformation oldeskewltoy 19 17,912 01-14-2021 04:41 PM
