The A6 Celica/Carina topic
02-14-2008, 11:33 AM
Post: #221
that ain't gonna fit, look at the difference in size of 4A-GE and 2T-G heads
![]() "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
02-14-2008, 11:41 AM
Post: #222
and another cool Celica to add....
![]() ![]() OOOOOOF "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
02-14-2008, 08:18 PM
Post: #223
gsrturbo Wrote:Dun think u will able to fit the 4a head into the 2T block cause its not from the same series and will not fit.What is needed to be changed to drop in a 4age? eg mounts exhaust... etc As i would probably set it up on carbs. What would the best carbs be? |
02-15-2008, 12:41 AM
Post: #224
webers, but you need to figure something out for your ignition
![]() Because that's not possible to use the old distributor without the ECU, you need to make an old style points distributor fit in the 4A-GE housing (i eblieve some 4K-C parts do fit ish) "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
02-15-2008, 02:52 PM
Post: #225
The Doctor Wrote:webers, but you need to figure something out for your ignitionWould twin 40 or 45s be the best or would a single 45 do? Is there much to the actual mounting of the engine? with the mounts and bell housing do you have to make up stuff or can you use ae86 or the carina mounts? |
02-15-2008, 06:35 PM
Post: #226
there are Carina/Celica AA63's, if you can find one, it's bolt on
![]() Just bolt the subframe over and the 4A-GE just slots in. Except for the rear axle, most Carina's use the AE86 rear axle, AA63s use the same rear axle as Supra's, IRS system. "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
02-15-2008, 10:48 PM
Post: #227
TA63 uses the IRS as well.
02-17-2008, 07:18 PM
Post: #228
Would the engine out of one of these celicas fit in? And what kind of back axle is on these celicas?
02-17-2008, 11:41 PM
Post: #229
engine would fit, if you take the complete front crossmember also.
It'll probably bolt in your own chassis. Rear axle is probably IRS, and that's a big nono on fitment, looked that on Banpei's Carina, but the rear floor is completely different. "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
02-18-2008, 01:24 AM
Post: #230
Another rusty old carina. | roman | 8 | 17,315 |
08-20-2007 12:56 PM Last Post: roman |
Amazing -musseum ready- Celica | nmwisima | 26 | 30,170 |
03-13-2006 12:42 AM Last Post: The Doctor |
ST185 celica evo 500 | SekiguchiUeno | 2 | 5,661 |
02-25-2006 08:53 AM Last Post: banpei |
Check out that old CELICA!!! | nmwisima | 12 | 16,409 |
07-10-2005 10:09 AM Last Post: banpei |
