The A6 Celica/Carina topic
07-23-2009, 03:14 PM
Post: #411
Iwan Vlaar? Dumb question
Damn, if I had known it washim I would have talked to him about a certain Skyline in his possesion... His Cedric 130 was parked right behind my Carina! Wink
[Image: AEU86 AE86 - The A6 Celica/Carina topic]
07-23-2009, 06:55 PM
Post: #412
yep, that guy Smile
07-23-2009, 08:13 PM
Post: #413
vraagje.. welke wielen zijn dat van WORK die onder de auto zitten van de doctor?
07-24-2009, 02:19 PM
Post: #414
Meister S1
07-30-2009, 10:58 PM
Post: #415
Hello there.
I'm experiencing some problems with my water temperature with the TA62 (3T engine). When its in opertaing temperature, its getting very high - nearly boiling tempearure. It never reaches that temperature, but goes between 70% and 95%. I chaged the thermostat - did not helped. A guy (who has a 2T-G in a E7 Corolla) said: this is normal, his temperature meter works like this also, but i'm not calm.
The temperature meter is doing this since i have the car (~ 7 months and 5000 km-s)
Any ideas? Is it really normal, or not? Should i change all the old water-pipes?
Thanks for your advice.
AndrewGL
07-31-2009, 11:39 AM
Post: #416
to check if it's the meter OR the car which is not good, i'd place another watertemperaturesensor + meter in the system and check.
Maybe the guy is correct, maybe not. But without decent checks, you'll never know Smile
07-31-2009, 01:05 PM
Post: #417
Mine never goes higher than 85% and my radiator is smaller than a normal radiator since it is shared with the autobox.
I'd say do what The Doc advises: see how high the temperature is when it reaches the redline. Normally this should be above the 100 degrees.
And don't worry if it does: the coolant mixture can get as hot as 120 degrees. Wink
08-04-2009, 12:26 AM
Post: #418
finally have an APK on the car, celebrated that with fitting the little spoiler i had laying since i bought the car! Big Grin
Hides the fact that the front valance is a bit wonky a bit Big Grin
08-04-2009, 08:29 AM
Post: #419
Congratulations on the MOT Doc, but if you don't mind me saying so, that little spoiler also accentuates the wonkyness a bit Tongue
Looks cool though Thumbs up!
A splash of fresh white paint would hide the inperfections a lot better I think, have you found the right color yet?
08-04-2009, 11:26 AM
Post: #420
no, but didn't bother. I can't use those motip cans on big surfaces, and Dennis is way to busy, so i keep it like this for now Smile
  Another rusty old carina. roman 8 18,866 08-20-2007 12:56 PM
Last Post: roman
  Amazing -musseum ready- Celica nmwisima 26 34,469 03-13-2006 12:42 AM
Last Post: The Doctor
  ST185 celica evo 500 SekiguchiUeno 2 6,577 02-25-2006 08:53 AM
  Check out that old CELICA!!! nmwisima 12 18,737 07-10-2005 10:09 AM
