TVIS
01-09-2008, 09:59 PM
TVIS
I had a good look around the engine today and decided to do the TVIS test by removing the vacuum tube. There appeared to be no difference with it connected or not. There is a definate engine note change at 5000rpm with the pipe on or off.
After connecting a longer piece of vacuum tube to the valve and sucking on it I could hear something moving around in the inlet manifold, I'm sure it was the TVIS working. If the TVIS was not working (stuck open) would I still get the engine note change and the extra pull at 5000rpm ? Thanks An analogue brain in a digital World |
01-10-2008, 12:08 AM
TVIS
yeah, you would, but you DEFFO gonna notice a BIG drop in torque in the lower rpms!
01-10-2008, 05:52 PM
TVIS
Around the 5000 rpms the engine gets a lot more fuel, so of course it will change the engine note.
01-10-2008, 07:19 PM
TVIS
Not more fuel.. there is a kick in ignition advance around the point where TVIS kicks in to make it more of a boost.. The actual TVIS doesnt make a huge difference.
01-10-2008, 08:02 PM
TVIS
The Doctor Wrote:yeah, you would, but you DEFFO gonna notice a BIG drop in torque in the lower rpms!May be it is stuck open then as I cannot discern any difference with the pipe on or off, is there an easy way to close the TVIS and keep it closed to check for this ? An analogue brain in a digital World |
01-10-2008, 10:42 PM
TVIS
Ivan141 Wrote:Not more fuel.. there is a kick in ignition advance around the point where TVIS kicks in to make it more of a boost.. The actual TVIS doesnt make a huge difference.I was refering to the speed-correction map in the ecu: http://www.jmross.freeserve.co.uk/part2p1.html Above 5000 rpm it starts correcting with adding a more rich fuel mixture. But when I re-read the explaination I see what you mean: fuel mixture is only 8% correction, so the effect shouldn't be that big to give the kick... 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
| Early tvis red top from e9 gti small or bigport? | Ryo | 3 | 10,024 |
| 20v silvertop exhaust manifold on 16v 2nd version tvis motor | Apsogos | 17 | 29,593 |
| my tvis doesnt work... | daywalker | 30 | 60,966 |
02-19-2012 01:25 PM Last Post: ZDoman |
| technical asking about TVIS | filh | 4 | 8,026 |
02-27-2011 02:07 AM Last Post: filh |
| TVIS close ignition switch??? | juantonwan | 2 | 5,083 |
07-27-2010 12:17 AM Last Post: totta Crolla |
![AEU86 AE86 - TVIS [Image: AEU86 AE86 - TVIS]](https://www.aeu86.org/sticker-banner-468.gif)
