TRD gearbox ?
04-07-2008, 01:09 PM
TRD gearbox ?
I have both the trd 1-5 and quaife gearset, great ratio's!
but you don't need any of those for drifting, because you're probably gonna break alot gearboxes..
just buy a 4.7 diff ratio
3x ke70, 2x te71, 2x ae86, 1x ke20 and 1x hilux
04-07-2008, 10:31 PM
TRD gearbox ?
Neither the TRD or quiafe kit will last if you abuse it. You might just as well go for a getrag if you are serious...
[Image: AEU86 AE86 - TRD gearbox ?]
04-08-2008, 03:52 AM
TRD gearbox ?
The T50 can break, but at AE86 Drift and N2 events I haven't seen that many gearboxes getting broken tbh - I don't remember any in the last year or so, but others might know better..
If using a T50 to preserve the box, be sure you don't fit a harsh clutch kit. Just a single plate TRD or RG is good and will handle 200 bhp.
VISIT OUR NEW WEBSITES!!!!
A Tuner's Paradise
Automotive Art On Film
04-08-2008, 07:03 AM
TRD gearbox ?
Yeah it depends a lot on the clutch and the driver. If you wait just a split sec allowing it to sync instaed of forcing it into gear will help a lot too.
04-08-2008, 08:18 AM
TRD gearbox ?
Super expensive. Might as well change out your rear pinion gear and save money.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
04-08-2008, 11:27 AM
TRD gearbox ?
what ring and pinion set would you mean is the best? (for my use of couse)
why drive, when you can drift
04-08-2008, 02:34 PM
TRD gearbox ?
If using a standard T50, then 4.5 is generally considered the best for track / drift use. Some use 4.778 but on std gear ratios this may leave the 1st two gears a little too low for drift use... Use a calculator to work out the vehicle speeds / revs to make a choice that suits you. Paz had found an online calculator program some time ago..
A Tuner's Paradise
04-08-2008, 04:39 PM
TRD gearbox ?
Well highest which you probably can get will be a 4.8 anyway.
I am looking for higher ones at the moment and nothing is available anymore. TRD discontinued their 5.1 and 5.3.
Speed Industries
Hurdnerwaeldlistr. 73
8808 Pfaeffikon
Switzerland
e-mail: [email protected]
phone: +4155 420 15 69
page: http://www.speed-industries.ch
MSN: [email protected]
We have all the parts your Hachi needs
04-08-2008, 06:14 PM
TRD gearbox ?
5.1 & 5.3 would really be usable for race use and full 5 speed close ratio boxes primarily. Pinion gear on those is so tiny it usually wears very quickly! TRD are phasing out a lot of parts for older cars which is fair enough. AE86's are all over 20 yeares old now. Not as bad as Mazdaspeed who have pretty much stopped selling parts for RX-7's - They've only been out of production 6 years! Crying
A Tuner's Paradise
  weird gearbox part2(possible trd set a) ditn 6 10,524 01-31-2016 08:01 PM
Last Post: totta Crolla
  T50 gearbox - TRD 2nd and 3rd gear hachirokkos 3 9,442 11-27-2015 10:06 AM
Last Post: Project D
  TRD Gearbox problem filh 9 11,019 06-03-2009 11:30 AM
Last Post: The Doctor
